airbag light ?
Old Jun 28, 2009 | 09:23 PM
dcjcdc's Avatar
Default airbag light ?
hi have 2002 s40 automatic 120,000 kms...
started the car today , turned it off for a few minutes and than started it up again and the airbag light came on
-- have one of those scanners obd2 scanners to read codes,,was thinking to scan code and than reset so the airbag light comes off
- read somewhere that this scanner will not read airbag light..is this true,,so i guess can clear airbag light
thoughts
Old Jun 29, 2009 | 08:56 PM
dcjcdc's Avatar
Default after looking at the manual
looks like its the srs light restaint system
tech where are you...you helped in the past..
thanks
Old Jul 5, 2009 | 08:06 PM
dcjcdc's Avatar
Default anyone
anyone that can help
thanks
Old Jul 5, 2009 | 09:27 PM
You need a scanner that can read SRS codes to be able to read them.
It could be many things you need to have the codes pulled to know where to look.
atlantadriver
Apr 26, 2021 08:25 PM
nandrolone
Jan 8, 2009 08:26 PM
donald1
Nov 8, 2006 08:38 PM
auburnvolvo
Jun 5, 2006 02:19 PM
2003bhoy
Nov 20, 2005 01:38 AM
