Iridium Sparkplugs and K&N Airfilter
Old Jun 30, 2009 | 10:00 AM
Maroubra Boy's Avatar
Default Iridium Sparkplugs and K&N Airfilter
Hi there,
I just got myself a 2002 S40T (B4204T3) abd I have just done the 105,000 km service. Just wondering if Iridium sparkplugs and a K&N panel filter replacement will improve the performance of the car. Anyone found any improvements with the K&N panel? Appreciate your thoughts on this.
Cheers,
Merrill
Old Jun 30, 2009 | 03:38 PM
jks2's Avatar
With the additional air flow of the K & N filter I think you will improve the performance. It may not be noticeable but it will improve. Also, when you look at it in the long run the K & N is probably cheaper than replacing a paper filter. Don't know about the plugs though.
Old Jun 30, 2009 | 11:13 PM
Do you reckon that the K&N will improve gas mileage in the long term?
Old Jul 1, 2009 | 10:11 AM
jks2's Avatar
I would think so. More air coming into the engine allows it to perform more efficiently. More efficiency = better gas mileage.
Old Jul 2, 2009 | 09:04 AM
Thanks for that! Do you reckon I need to reset the ECU after the filter has been installed or driving around for while will allow the computer to adapt?
Thanks a lot for the advice you have been giving!!
M
Old Jul 2, 2009 | 09:47 AM
jks2's Avatar
The computer will adapt to the increased air flow. No need to touch the ECU.
Old Jul 29, 2009 | 03:39 AM
bigvolvo's Avatar
just bought 2001 s40.
immediately i change air filter to k&n and last weekend, i changed the spark plugs to iridium lx.
wow, it is very very very noticeable.
highly recommended. ( now, i want to use iridium to my all other cars)
gas mileage improved a bit after using k&n but i have got to the point to check after spark plug change.
Old Jul 29, 2009 | 07:40 AM
Nice one!
I actually ordered a Pipercross panel of Ebay and am waiting for it to arrive. Did you use the NGK BKR6EIX plugs? Did you have to regap the plug before installation?
Cheers!
Old Jul 29, 2009 | 06:50 PM
bigvolvo's Avatar
ngk bkr6eix 6418 and i did not have to adjust the gap.
i used a torque wrench and apply some anti-seize(?) oil.
first time i started, the 'check engine oil' was off. i drove it for a while then it was off. i assume that computer was adjusting something.
Old Jul 29, 2009 | 11:39 PM
DOHCRT's Avatar
Spark plugs will not increases an engines power output unless the ones you're replacing are worn out. It doesn't matter what material or how many electrodes. There is no magic spark plug.
fivespeed
Mar 22, 2007 04:23 AM
suter
Jan 2, 2007 10:41 PM
thejman
May 9, 2006 11:07 PM
thejman
May 4, 2006 01:10 PM
nandrolone
Oct 13, 2005 01:44 PM
