How does cruise control work?
Old Nov 1, 2005 | 12:55 PM
andrews65's Avatar
Default How does cruise control work?
I using a 2003 XC70 temporarily and there is no manual. When I press the cruise button and take my foot off the gas the speed just drops. What am I doing wrong?
Thanks.
Old Nov 1, 2005 | 02:02 PM
ZIGZAG's Avatar
Default RE: How does cruise control work?
Dont know about XC70 but my S40 you have to turn the cruise on then press set button. I have a switch on the signal stick.
Old Nov 1, 2005 | 08:32 PM
ORIGINAL: andrews65
Thanks.
Did you turn the button on the steering wheel on first?
You turn it on by pressing the buttom once.The word Cruise will appear I think in the milage screen or somewhere close when it is on.
Old Nov 2, 2005 | 01:45 AM
Red XC's Avatar
Oh I've used it many times.
Have the car at a certain speed like 60mph (CC only works speeds above 25mph)
Push the Cruise button on steering wheel
When the light "cruise" turns on the cluster
Push the "+" button and hold it for a few seconds, let it go, it should set the speed
To stop cruise control, you can brake, push the O/ zero button
To resume cruise control at same set speed, please the half circle button, the XC should accelerate to the set speed (this only when cruise control light is still on)
To reduce and gain speed: + and -
hope this helps!
Old Nov 2, 2005 | 02:32 AM
Red XC's Avatar
Since you dont have a manual, I do recommend you to print this out or buy a manual from volvotechinfo.com or you can go here to print it out:
http://www.volvocars.us/_Tier2/Owners/Library.htm
2003 XC70 Owner's Manual: http://apps.volvocars.us/ownersdocs/.../03xc70_00.htm
here is the page for the cruise control: http://apps.volvocars.us/ownersdocs/...0_02b.htm#pg33
if u want to know any XC problems you want to know or info about the whole car, visit volvoxc.com for details.
Balor T Stout
May 31, 2014 09:09 AM
rspi
Jul 31, 2012 07:38 AM
Fishburn
Sep 15, 2010 12:47 AM
magoo0903
Nov 17, 2009 11:01 AM
tenchu
Feb 29, 2008 08:11 PM
