Door open signal all the time Help????
Old Nov 1, 2005 | 03:49 PM
jchris19782003's Avatar
Default Door open signal all the time Help????
I have a 99 S70 been a pretty good car, but now the door open ding sounds continuously and the dome light stays on all the time. Anyone know of a fix for this or a way around it? Maybe you had the problem before and got it repaired. Mechanic says replace the drivers door latch but I want to get a fix that is for sure and not a part replacement at $$$$ high cost without a fix. Appreciate your help.
Old Nov 1, 2005 | 08:43 PM
Default RE: Door open signal all the time Help????
My vote is for the door Latch assembly as well.
The switch that controls the lights is part of the latch assembly.
Old Jun 19, 2010 | 07:04 PM
pargar's Avatar
i half to close the door twice to make the light on the dash go out
Old Jun 19, 2010 | 11:11 PM
Lube the latch real good while it is still working. Matter of fact, you may want to lube all of the door latches.
Old Jun 25, 2010 | 07:48 PM
karlb's Avatar
Jump the wires for the switch and be sure before you spend the money on the latch.
klod622
Jan 31, 2010 06:11 PM
tobra
Sep 7, 2009 10:21 AM
kh0007
May 6, 2009 07:15 PM
