Installing a Parrot MK9200 i Bluetooth XC90
Old Sep 19, 2009 | 06:28 AM
hedam69's Avatar
Default Installing a Parrot MK9200 i Bluetooth XC90
HI everyone..
Does anybody have any experience with installing additional eqipment in a Volvo XC 90 from 2004 with Premium sound system, the one with fiber optics?
I need a cable that can connect with the CAN BUS to the headunit, and where i can connect the parrot bluetooth adapter.
Hope someone can help me with this issue - Thx
Old Sep 19, 2009 | 09:08 PM
m1964's Avatar
I installed Parrot Ck3100 in to '05 XC90 using Volvo Original BT harness-Volvo sells its own harness and relay made for Volvo BT kit (made by motorola). I had to slice Parrots power wires and speaker output wires into Volvo harness, but otherwise it was a Plug-and play solution where sound comes only from 2 front speakers, and rear speakers are muted.
If you search here or on Swedespeed.com there is detailed description of installation of Volvo's BT kit
Old Sep 21, 2009 | 03:05 AM
hedam69's Avatar
Super - thank you very much for that reply - that was very helpful.
Old Oct 4, 2009 | 12:06 PM
m1964's Avatar
Don't use switched power from Volvo harness by steering column-use switched power from cigarette lighter /power socket by the radio-if you use power from the OEM harnes, the switched power remains ON about 2 min. after you turn OFF the ignition-so BT remains ON also for 2 min. basically u leave the car and someone calls you-the call goes to the car's BT not your cell within 2 min. after you left the car... very annoying...
Tell Us how it went- the install..
Old Jun 21, 2010 | 12:37 AM
2010stephencook's Avatar
was it successful man? how did the installation go?
Old Jan 13, 2012 | 11:38 AM
jmbreitinger's Avatar
I have the Volvo unit and want to upgrade to the Parrot but this is over my head. How would I find an installer in Minneapolis who could do this?
Kentor
Dec 24, 2018 01:33 PM
Scottish Thistle
Apr 21, 2014 05:26 AM
mark8008132
Jul 14, 2011 04:25 PM
Keithjones1400
Jul 5, 2008 02:18 AM
greenyman
Jun 20, 2008 03:08 PM
