wtb turbo
Old Oct 12, 2009 | 06:13 PM
mark850t's Avatar
Default wtb turbo
hey there . since no ones interested in my car i want to upgrade the turbo. does anyone have anthing bigger then a 13g thats bolt on to sell me ? would like to upgrade it soon . ppl let me know pleaser and thank you.
mark850t
turbo needs to bolt on to a 96 2.3 l turbo motor.
Old Oct 12, 2009 | 06:31 PM
Post this in the wanted section, probably get more hits there. And I would check ebay and VS as well, there's always turbos there. Any TD04 turbo will be a bolt on. 15G, 16T, 18t, or 19T.
If you have a 2.3l motor than you should have a 15G, not a 13G.
Old Oct 12, 2009 | 06:39 PM
Somthngfrce's Avatar
Honestly, check Volvospeed. There's a few 15 and I believe 1 19 currently for sale.
Old Oct 12, 2009 | 07:16 PM
I've seen an add for a 15g on ebay right now for 60 bucks.
Old Oct 13, 2009 | 12:17 AM
TIPSP's Avatar
Got Boost?
not true...
it is any TD04HL you want. TD04 are for rwd.
Old Oct 13, 2009 | 06:25 AM
Well that's what I meant, I couldn't remember the last couple letters. I was hoping nobody would notice and I would still look right, thanks for pointing that out.
lulz
Old Oct 13, 2009 | 10:12 AM
TIPSP's Avatar
Got Boost?
lulz
no problem man!
dont feel sad!
Old Oct 13, 2009 | 10:37 AM
Legendsecko87's Avatar
TD04HL 19G on ebay.
Old Oct 13, 2009 | 11:26 AM
If you do have a 13G on your car, that means that you should have the 2.4l engine. If that is the case, I would recommend a 16T for a nice upgrade. I don't think I would put a 19T on the 2.4l engine especially when people are weary to put them on the 2.3l engines.
Old Oct 13, 2009 | 12:01 PM
fcpgroton's Avatar
Former Sponsor
+1, do not put a 19T on a LPT engine. The outcome would not be good.
Anyway, putting the 16T in there with a T5 ECU would make that one great car.
Old Oct 13, 2009 | 12:20 PM
+1 to him. That would be sweet.
But I still want to clarify, OP said he has a 13G and a 2.3l engine. That doesn't add up. Unless you downgraded your turbo.
Old Oct 13, 2009 | 07:35 PM
mark850t's Avatar
well iam not 100 % sure what turbo is on my 2.3 , i know it is a stock turbo low pressure and iam sure its a 2.3.
i cant seem to find any turbos at a decent price on ebay .
does anyone on here have one handy.
Old Oct 13, 2009 | 07:54 PM
TIPSP's Avatar
Got Boost?
Check this thread.
https://volvoforums.com/forum/private-wanted-classifieds-archive-34/looking-turbo-just-turbo-parts-read-32404/
Old Oct 13, 2009 | 08:12 PM
Well that's two opposites again. The 2.3l engines are the HPT engines, and the 2.4l engines were the LPT. STOCK 2.3l HPT 15G vs STOCK 2.4l LPT 13G. If your car is an 850 TURBO and not an 850 GLT, then you should have the 2.3l engine and the 15G turbo.
Now if you have a 15G, you can upgrade to the 16T although it's not a huge upgrade, they boost a little bit more. I think with the 15G 15psi is out of efficiency, I think the 16T can run around 17 PSI and still be efficient. You can upgrade to a 19T, but then you have to be careful about your internals. And you would need several supporting mods for a 19T.
Old Oct 14, 2009 | 10:03 AM
There si a 15G Locally for 200 if you are intersted, PM me if you want it.
Old Oct 14, 2009 | 10:40 AM
I have a feeling he has a 15G on his car.
Old Oct 14, 2009 | 10:56 AM
mark850t's Avatar
yeah i know its a stock turbo 850 . so its the 15 g then eh .
so would the tdo4hl work on my car for a direct bolt up ? bolt up to downpipe and have the same intake location?
pm md you legendsecko87
Old Oct 14, 2009 | 11:02 AM
Well he has a 15G then that's no upgrade. And you said this is going on a 96 right? If so then you should have a straight flange exhaust housing. There are three types of exhaust housing, straight, angled, and conical, all turbos are bolt up to the exhaust manifold, but you have to make sure you use the same exhaust housing to bolt up to the DP.
Old Oct 14, 2009 | 02:28 PM
mark850t's Avatar
yeah 96. so is it harder to find a bolt on turbo for a straight flange?
Old Oct 14, 2009 | 02:35 PM
No, it's about even. 94-95 they used conical housing, 96-97 they used straight. And then the 98-whenever V70Rs have angled housings. All TD04HL's are bolt ons, you just need the appropriate exhaust housing to bolt up to the DP. If anything, get a turbo and just use your housing. The housings are all interchangeable.
