Welcome to Volvo Forums!
Welcome to Volvo Forums,
Old 10-13-2009, 01:50 PM
850tony's Avatar
850tony 850tony is offline
Send a message via AIM to 850tony Send a message via MSN to 850tony
Default MCC removal
it has been asked that some instruction be given to help with the removal of an mcc seeing as its not exactly the easyest thing to do.
begining steps:
1) remove radio - push in the two upright rectangular peices on the lower right and left of the radio, pull radio out and unplug. make sure you have the radio code before hand
2) remove all three knobs on mcc - to help with removal a pliers of channel lock may help, dont crack the knob though.
3) remove the two screws holding the face plate on - there are two screws behind the driver and passenger heat control knobs
4) remove the face plate - i usualy use a flat tip screw driver and give it a little pry here, and a little jimmy there untill it comes out
5) remove the four screws holding the mcc unit in place - these screws are located at the four corrners of the white unit
***beer break***
this is the part that it starts to get a little tricky. what needs to happen in the cables need to be moved from the mcc. this is easyer said then done, but hopfully my steps will help.
1)using a t10 torx remove the three screews holding the black cover onto the mcc. keep track of these screws, you may need them for spares
2)remove the retaining C clip from the front of the mcc (air flow knob)
3)start to remove the control arms that are connected to the cables (walk through the pictures below)
pull out center round cam knob
remove clicker ball
remove last black arm
***BEER BREAK!!!***
these are the clips that hold the cables onto the mcc. best thing i can say is try using a needle nose pliers or maybe a flat tip to realease them out of the mcc (or if you dont care just crack the mcc)
there are three on the driver side, and one on the passenger side
the two remaining cables are on the far driver side. and the far passenger side.
removal is quick and easy, both remove the same way, they are almost identical)
with that all done, assuming you have already removed the cable clips that are holding the cabels to the the mcc white plastic, you should be able to turn and twist out the mcc unit.
hope that helps, let me know if you need a larger picture, or more instructions.
__________________
94' volvo 850 wagon non-turbo automatic - burgundy
94' volvo 850 wagon non-turbo manual - silver
00' volvo s40 sedan turbo automatic - sliver
if the brakes didnt squeal it wouldnt be a volvo...
Old 10-13-2009, 07:32 PM
tech tech is offline
Nice write up I am pinning it.
__________________
1995 Yellow T5-RM Broken
1996 850 turbo
Tags
mcc, penta, volvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
Volvo Accessories
- Dog Seat Covers
- Husky Liners
- EBC Brakes
- Hawk Brake Pads
- Car Floor Mats
- Wood Dash Kits
New Sponsors
© Internet Brands, Inc.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
