o2 sensors on a 1996 850 glt
Old Nov 1, 2009 | 08:59 AM
dholmes83's Avatar
Unhappy o2 sensors on a 1996 850 glt
ok i have replaced the rear o2 sensors twice in the last two weeks the first was after market and was told that would be the reason for the check engine light came back on so i got a oem o2 sensor and the code came back what could be the proble it is code po141
please help i dont want to give the car back but looks like my only option at the moment
please plaese what eles could it be ???
Old Nov 1, 2009 | 09:12 AM
aftermarket O2 sensors work, the sensor doesn't cause a code because it's not OEM, it's just how well they work that you get a CEL. Have you looked up the code?
Old Nov 1, 2009 | 09:21 AM
dholmes83's Avatar
Default yes
o2 Sensor heater bank 1 sensor 2
Old Nov 1, 2009 | 09:25 AM
Maybe you have a poor connection. Could possibly be a clogged cat that is just ruining the O2 sesnor.
Old Nov 1, 2009 | 09:51 AM
dholmes83's Avatar
i have checked all that stuff and seem to be ok ....
Old Nov 1, 2009 | 03:53 PM
dholmes83's Avatar
any one have anyother ideas???? this is really plaging me and i love this car
Old Nov 5, 2009 | 11:49 PM
gdog's Avatar
You're going to have to trouble shoot it. The code is telling you the heater portion of the rear O2 sensor is open. If the open is not in the sensor, then it's likely in the harness somewhere between the ECM and the sensor.
Get your DVOM out and get to work...
http://www.obd-codes.com/p0141
Old Nov 6, 2009 | 07:57 AM
Bobec's Avatar
I read on another thread that you have to disconnect the battery for about 10 minutes after you replace the O2 sensor so the ECU can re calibrate it's stored data.
Old Nov 6, 2009 | 09:45 AM
gjz30075's Avatar
Make sure all your vacuum hoses are in good shape. I fought the same thing for a while until I found crumbly vacuum hoses that I'm sure were leaking. I disconnected the battery for a few minutes after each fix.
Old Nov 14, 2009 | 06:20 PM
dholmes83's Avatar
had the ecu replaced and seemed to fix problem
Old Nov 16, 2009 | 02:11 PM
I had a bad rear O2 sensor. It gave me a CEL code P0137 I believe. Here are photo instructions showing how I replaced mine: http://www.atthetipwebs.com/technolo..._O2_sensor.htm
ronzara
Mar 3, 2012 10:47 AM
seecamerasmile
May 31, 2011 01:46 PM
dock
May 16, 2009 09:29 PM
diman
Oct 26, 2007 07:31 PM
rfa1972
Apr 19, 2007 03:36 AM
