Welcome to Volvo Forums!
Welcome to Volvo Forums,
Old 11-05-2009, 05:48 PM
Riculus Riculus is offline
Angry NO Start, cranking but not turning over
I droped of my daughter at school this morning and when I came back to go the car just did not want to start. I stay there and tried and tried. It finally turned over and I went straight to the mechanic. He checked to see if there was power going to the plugs, distributer and coil. He said the power was low. Checked to see if fuel was coming to the injectors, it was. He happened to have a coil and crank sensor on hand so he changed them both. He then did the same test and found out that fuel is not coming to the injectors. What can it be? Is it my fuel pump is not working properly, the fuel pump relay or any other problem?
Any help will be gladly appreciated.
Riculus
Old 11-05-2009, 06:08 PM
blackbrick's Avatar
blackbrick blackbrick is offline
things to check:
1. fuel pump relay
2. fuel pump
3. fuel filter
4. fuel pressure regulator
__________________
04 S60 2.5T
96 850 n/a
97 Suzuki Sidekick Sold
things that changed mankind are fire, wheel and Internet
Old 11-05-2009, 08:20 PM
redbottle's Avatar
redbottle redbottle is offline
Try the Cam sensor instead and not the Crank sensor...I had a similar prob and tried it all, I replaced the speed sensor( GLT on the fram under the radiator) inside the slots just below the windshield on Turbo models.
Cam sensor (used)
Crank sensor
speed sensor
try them out used first...
__________________
RR
Old 11-05-2009, 08:23 PM
redbottle's Avatar
you will get no fuel sent to injectors if your cam sensor or crank sensor does not make a full circuit...nor will you get spark from the coil connection not the positive and negative cables red/blue...my post was freakin long I don't know if it is still hanging out...ASK Tech
__________________
RR
Old 11-05-2009, 08:29 PM
redbottle's Avatar
I was reffering to the sensor that sits just below the distributor cap, move it away from the distributor cap if it is not secure already...this can be the problem...
__________________
RR
Old 11-05-2009, 09:52 PM
rspi rspi is offline
Send a message via Yahoo to rspi
I just had a start problem with my 2004 Jeep Grand Cherokee. The symptoms were as follows:
1. Cranked but would not start.
2. Could not hear the fuel pump when I tried to start it.
3. Could not read codes, the OBD-II code reader would not link to the computer.
4. Frustraded the heck out of me.
My problem was the Crankshaft Position Sensor.
__________________
'95 850 R - Yellow, 95k - My Precious
'97 960, 85k - Wife (Driven 600 in last 7 months)
'98 S70 GLT, Unk - Maybe 143k - Daughter - (Getting beat the crap at college campus)
'04 Jeep Grand Cherokee, 94k - Wife (Finally Sold!)
Men's Fraternity
Old 11-06-2009, 03:38 AM
Squiggy's Avatar
Squiggy Squiggy is offline
Hey'a. I'm having the exact same problem with my 1994 850 as Riculus. Car was running perfectly then... just wouldn't start. Cranks but no start. Very frustrating!!! When you say the 'Crankshaft Position Sensor' this can confuse some people. There is a CRANKSHAFT sensor (also known as the 'Turbo Reference Sensor' or 'RPM Sensor' located just below the distributor cap) and a CAMSHAFT sensor. Are you referring to the CRANKSHAFT/TURBO REFERENCE/RPM Sensor...? Thanks.
BTW I replaced my RPM Sensor and it didn't help at all. Even though the code 214 said it was the RPM sensor, no dice.
__________________
1994 Volvo 850 Turbo Wagon. 173K miles. Owner since 165K miles. First Volvo.
Old 11-06-2009, 11:24 AM
confused_al's Avatar
confused_al confused_al is offline
How is you fuel pressure(FP)? That gives you confirmation of either you have problem of fuel delivery system preventing you from start or not.
- If your FP>40psi at the Schroeder valve on the end of the fuel rail, then the fuel delivery is not the one.
- If you have no or low FP, do you hear the "buzzing" sound when your key is turned to pos II? (1) if its no, jump your fuel pump relay (2) still no, give a smack at the bottom of your fuel tank see if your pump comes alive (a new pump should be ordered ASAP); (3) still nothing after smacking, check your pump getting power or not and see if it works with direct 12v.
If it is not the fuel delivery system, do you have sparks? do you have power to injectors?
__________________
95 850 GLT
06 V70
Old 11-06-2009, 02:53 PM
Thanks for all the support. I was getting spark, the shop called and they replaced the fuel pump. Have to test drive and i will pick it up later. keep youm guys informed
Old 11-07-2009, 12:53 AM
s_moneh s_moneh is offline
Quote:
WRONG! to justify this this just happened to me
EVERYTHING in the car was replaced, from crank shaft sensor, all the way to spark plugs, however 1 sensor was missed and it was indeed the camshaft sensor, i was gettign fuel i had everything but a spark, replaced the camshaft and voila i have a beautifully running 850 t5 now
Tags
access, cam, cherokee, crank, cranking, fuel, grand, jeep, problems, pump, relay, s40, sensor, start, starting, turning, volvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
