Welcome to Volvo Forums!
Welcome to Volvo Forums,
Old 11-06-2009, 11:57 AM
BC-TX BC-TX is offline
Default 1996 850 Turbo ECU
Will the computer out of a '95 work in a '96?
Old 11-06-2009, 11:59 AM
gilber33 gilber33 is offline
1994 Volvo 850
My Garage
Yes, but you'll have a CEL due to no EGR on the 96 model
__________________
http://volvoforums.com/forum/image.php?type=sigpic&userid=15871&dateline=125711  5530
'94 854 Turbo
-IPD plug wires|poly upper engine mount|K&N box filter|modded intake|straight turbo housing|3" Down Pipe|2.5" catback|
'94 855 Turbo
-total rebuild- Project thread clickz here
Officially: 16T, T5-R bumper, T5 motor w/104k, M56H, 17" Tethys
Old 11-06-2009, 01:49 PM
Cool...Also, I have an issue with smoke at idle. It is only at idle and after it has warmed up. Driving normal, never an issue. Any idea what that could be? I am fairly certain it is not valve seals or any other valve related issue. I was in the engine pretty deep when I purchased the car and it looked great.
Old 11-06-2009, 02:19 PM
boxpin boxpin is offline
Are you 100% sure about that? When I was swapping engine from my T-5R to my Turbo Wagon. Both cars are 1995, but the electrical was different. The harnesses were different. Ground points were in different locations, Plugs were in places where there werent plugs on the other car. Totally different harnesses. Now maybe that was due to one being a T-5R but I in no way wanted to risk using the other harness in the wagon so I disconnected everything from the engine/trans instead of just releasing the harness at the ECU box. Maybe it can be done, I dont have experience in that area but this I know, the harnesses were seriously different. Double and triple check before you start plugging ECU's in.
__________________
BOXPIN
95 850 Turbo Wagon w/T-5R engine. IPD ECU, Modified Cold Air Intake, MSD Ignition, 2 1/2" exhaust, Flowmaster, Manual Boost Controller, IPD Swaybars.
Old 11-06-2009, 05:01 PM
1994 Volvo 850
My Garage
What did you do to make it work?
__________________
'94 854 Turbo
'94 855 Turbo
Old 11-06-2009, 09:18 PM
I kept the same harness that was in the wagon from the start. Meaning, I replaced the engine and trans but left all the wiring in the car and plugged it back into the new parts. The engine and trans have the same sensors, etc so it all plugged back in. What I worry about is the rest of the harness. My harness had an additional plug mounted to the drivers headlight bucket and the main ground was attached to the fender. I could not find the main ground in the T5 and it did not have the additional harness and plug. They were way different. Maybe everything is routed to the correct pins in the ECU but maybe not. I would look at the numbers and try to get the same number to replace it with. Another option is IPD, they knew the ECU's very well and at one point said I could swap with another number. They may know the answer here.
__________________
BOXPIN
Old 11-06-2009, 10:57 PM
1994 Volvo 850
My Garage
But everything was there for the motor and trans?
/thread jack. lol. sorry.
__________________
'94 854 Turbo
'94 855 Turbo
Old 11-10-2009, 01:45 AM
denver005 denver005 is offline
BC-TX,
I too noticed the smoke issue you mentioned in your post. It feel like a smoke screen when I drive the car in the morning after few minutes of warm up. Interestingly, no such smoke is noticed rest of the day.
Tags
1996, 850, codes, ecu, meaning, meanings, turbo, volvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
