Dash and Gear Shifter Lights
Old Dec 5, 2005 | 05:24 PM
grazbro's Avatar
Default Dash and Gear Shifter Lights
I have a 98 S70. Half the lights (LED's) on the stereo are working (right side) and the left side are not. The 2 heated seat switches (heated seats do work) dont illuminate and the auto shifter indicators also don't work, but the ECONO, SPORT and WINTER trans switches are illuminated. Any others have this problem before?
I checked all fuses and none are blown. All switches work too. Just not lit up!
DONE!
Old Jan 31, 2006 | 01:54 PM
afoic2005's Avatar
Default RE: Dash and Gear Shifter Lights
Hello grazbro
I have the same problem with the LED lights not workin on the left side and the shifter panel. I'm workin on the radio right now and here are the links to fixes on this site and on Volvo Speed Forums (https://volvoforums.com/m_2141/tm.htm)
(scroll all the way down to the long post- https://volvoforums.com/m_10129/tm.htm). As for the Shifter Panel lights, I'm still tryin to research that myself and will let you know if and when I find something
Hope it helps
Old Apr 2, 2007 | 01:00 AM
vc_wannabe's Avatar
Open the center consol up, open the little door/cover.. there are two 8mm bolts unscrew them. The plastic around the ebrake, pull twards you and pull off. Now lift up center consol. There is a white peice under the shifter, the bulb is in there. Dont know the part number or what size bulb but if worse comes to worse you can get it at volvo for like $5
JGoods
May 22, 2011 09:09 PM
jasond011
Sep 13, 2010 04:02 PM
Dainos
Jan 6, 2009 08:02 AM
grazbro
Dec 12, 2005 10:58 PM
