HELP! FIRST VOLVO
Old Jun 23, 2004 | 03:38 PM
FLTONY's Avatar
Default HELP! FIRST VOLVO
Got my first volvo its a 1995 960 sudan a cool car ,but where do you check the transmission fluid at Im used to american engines a picture or detailed message will be most helpfull thanks alot!!</P>
Old Jun 30, 2004 | 06:15 PM
chuckcolomb's Avatar
Nice car. I have a 1992 965 with 279,000 km on it. Use it for winter and in summer for load hauling - very nice. Too bad they're all automatic.</P>
Look deep down at the firewall on the driver's side, just beside the engine. You'll see a yellow plug with a 1/2" square depression in it. This is the transmission dipstick! It's held in place by a spring clip and seals with an o-ring. Turning it a little and pulling up will get it out.</P>
You can use a 1/2" socket drive extension as a handle so you don't have to stick your hand in so far when the engine is running. Crazy design.</P>
Old Jul 30, 2004 | 03:44 PM
garyw38's Avatar
Old Jul 30, 2004 | 03:47 PM
garyw38's Avatar
There is no transmission dip stick for your car. The transmission is a sealed unit. It is serviced at a transmission shop, or the dealer. Once serviced it does not need to have fluid check every so often unless you have a leak or a problem eith the transmission.
Old Oct 9, 2004 | 02:18 PM
The Jesda's Avatar
Default RE: HELP! FIRST VOLVO
There is a dip stick for the transmission as Chuckcolomb said, it has has yellow top held secure by a side mounted spring on the tube which goes into the gearbox casing. I recently had my transmission fluid changed and watched the workshop check the level using it.
Regards Darren
xszydx
Aug 18, 2012 06:26 PM
djforresta
Jul 4, 2010 11:15 PM
volvomang
Aug 23, 2009 02:13 AM
glkprhog
Jul 4, 2007 02:39 PM
USSEnterprise
Sep 30, 2006 05:49 PM
