Secondary Air Inj. (P410) code
Old Dec 20, 2005 | 09:54 PM
tom1568's Avatar
Default Secondary Air Inj. (P410) code
ok so i got this code p410 and it is the secondary air injection malfunction code, any ideas? the air inj. pump works fine, the check engine came on while i was driving at a steady 45 mph , there is a valve that controls air into the pump, but is this item able to be cleaned, or do i have to replace it, also is it more typical of a switch to go bad, the vacuum switch that sends out electrical signal telling the computer diagnostics.
1998 Volvo V70XC AWD
thanks to all.
tom
Old Dec 20, 2005 | 11:29 PM
Default RE: Secondary Air Inj. (P410) code
The metal valve on the back of the head might be clogged if it has one.
Are you sure the pump works?
It only comes on for about 30 to 60 seconds when the car is fully cold. After sitting over night or all day.
Old Dec 21, 2005 | 07:58 PM
tom1568's Avatar
no i havent checked it however volvo says that when the start to go bad they make a winning sound like a blow dryer. what is the best way to check. also is the control valve cleanable?
thanks
tom
Old Dec 21, 2005 | 09:36 PM
Yes the pump will sound kind of like a hair dryer.
If it is eaven working. Most of the time they will fill with water and short out.
Sometimes cleaning the valve will work other times they need to be replaced.
Kiss4aFrog
Feb 6, 2012 11:36 AM
shanegarr
May 22, 2006 12:32 PM
atto
Dec 29, 2005 09:17 PM
atto
jrw
Nov 19, 2005 09:13 PM
