V70 "creaking" noises
Old Jan 27, 2006 | 10:20 PM
snyderv70's Avatar
Default V70 "creaking" noises
I have a '98 V70 and the front passenger side strut is making a creaking noise. It's noticebly louder when I start driving when it's cold outside, however I still hear the noise when I drive. it does not get louder if I go over a big bump. it's a creaking, crackling noise, especially going over small cracks and bumps in the road. could this simply be the plastic piece under the hood on top of the strut? And, if it is, can it be replaced easily? Thanks
Old Jan 28, 2006 | 09:56 AM
Default RE: V70 "creaking" noises
It might be your upper spring seat. Test by trying to turn the top strut nut. If the nut turns easy it is bad.
If it won't turn and feels rubbery it is good.
odonnebj
Jan 16, 2011 09:05 AM
HummerGuy
Jun 29, 2009 08:43 AM
jcseymour
Mar 20, 2006 09:09 PM
jcseymour
Mar 20, 2006 02:05 PM
indagutter
Oct 11, 2004 07:10 PM
