replacement key
Old Aug 5, 2010 | 03:32 PM
gverholek's Avatar
Default replacement key
I bought a 2009 C70. It had one key. I want a backup. I bought a key on eBay, but the Volvo dealer says it cannot be reprogrammed to my car. True or not true? What do I do now?
Old Aug 5, 2010 | 03:39 PM
jks2's Avatar
The newer cars have keys that have a RF microchip that is programmed to your car. Without the chip the key is useless (you might be able to get it cut to open the trunk or something, MAYBE) but as far as starting the car, no.
Only thing to do is see if the previous owner still has a key or shell out BIG bucks to buy a programmable one from the dealer.
Old Aug 7, 2010 | 06:21 PM
elav's Avatar
CopyThe key with non-chipped blanks and take the original key and tape it under the dash. The original key will do the RF part and the copies will turn the ignition.
Old Aug 9, 2010 | 10:21 PM
mkc70's Avatar
May cause a draw since the key is probably active RFID and not a passive like older models.
Old Aug 10, 2010 | 12:20 AM
dale66vt's Avatar
I suspect above concern is valid. Recently, when I purchased my 2007, the dealer warned against leaving the key near the door or the dash, as after a couple days it would drain the battery.
Old Aug 10, 2010 | 06:21 PM
gverholek's Avatar
Thanks for the responses, but it doesn't seem that I have a choice but to buy a VOLVO key and have them program it. Communists!!!
On the other hand, Dale66vt, why would that drain the key's battery? Does it turn off once the car is started? If it doesn't, you can't take the car on an extended drive.
Sorry, it just seems lame that a car company would build such gestapo measures into a product designed to please the customer. Love the car; hate Volvo.
Old Aug 11, 2010 | 12:45 AM
dale66vt's Avatar
My understanding was it's not the key's battery; but, the car's battery that would drain down.
I believe the car receives a signal from (or senses) the key, above any input when you press a button, such as to unlock or lock the car.
I could be completely wrong and will try to do a little further research.
Old Aug 11, 2010 | 01:31 AM
dale66vt's Avatar
Couldn't find anything that confirmed what I thought I was told.
FYI, manual is available on-line at http://new.volvocars.com/ownersdocs/...0/07c70_00.htm
Sorry I couldn't be of further assistance.
Old Aug 11, 2010 | 04:28 AM
irbrenda's Avatar
I have an '08 and since the day I got it, May 2008, I have left my keys in the console by the shifter while parked in my garage. Only time the keys are with me is when I park away from home. All winter the car is not used and those keys remain in the car. Never had a problem with the car battery.....yet! Never thought about it either. I need to research this a bit.
I had heard a similar tale about my VW Touareg..that even parked in my garage, I have to set the alarm or the car battery would drain. Never happened. The only complaint I've heard about the battery draining is strangely enough when parked for a lengthy time at an airport.
Old Aug 11, 2010 | 07:25 AM
mkc70's Avatar
Under the impression we are discussing specifically keyless go style systems and not just a smart card key fob. Do both your VW and C have one, or does the OP have one. Rereading the posts I think we are on different systems.
Old Aug 26, 2010 | 10:45 PM
dale66vt's Avatar
gverholek-
I was looking though www.volvospeed.com and came across a link to a key/keyless/etc. outfit. You might call them and see what you can learn.
https://www.ikeyless.com/testimonials
https://www.ikeyless.com/about
https://www.ikeyless.com/vehicles/Volvo/C70/2009
Let us know how you do and what you learn.
Regards.
Old Nov 9, 2010 | 06:08 PM
phaedrus's Avatar
Default Remotes & Keys
Just picked up a 2000 c70 convert, promptly lost only key/fob. (Had spousal help.) So tow into dealer and $410 later have key fob and 2 keys. Did the 2k have the 'active' chip in the key, too? If not, I'll be putting the extra someplace under the dash. Will the key disable the alarm without the fob?
Is there an owners manual out there for this one, too?
thanks, John
Jimal
Dec 27, 2015 03:17 PM
dhines46
May 20, 2010 10:58 AM
gary2
Jul 21, 2008 05:53 PM
joseangel
Jun 18, 2008 07:18 AM
fishpen
Sep 2, 2005 09:53 PM
