oil chg with Full synthetic
Old Aug 6, 2010 | 08:40 PM
Porkchop99's Avatar
Default oil chg with Full synthetic
I was wondering the school of thought on when or if it is necessary to chg the oil filter more then every 6 months that I chg the oil using full synthetic.
The oil filters that I use are MAHLE OX 149 D on my 2001 S60 120K mi
Thanks!
Old Aug 7, 2010 | 09:34 AM
ikey's Avatar
You'll find many different opinions about change intervals on these forums, but two things remain consistent: Use full synthetic oil and don't rely on Volvo's 7.5K mile interval.
Personally I change my oil every 5k miles or six months (whichever comes first) with a full synthetic oil and always replace the filter with one from an OEM brand.
Old Aug 8, 2010 | 12:42 PM
malaka's Avatar
Me too. Cheap insurance, I figure. Sort of like not believing that Volvo transmissions never need fluid replacement under "normal" driving or that the coolant lasts forever. Fluids are way cheaper than mechanical parts replacement. So are filters. As the old Nike ad used to say: just do it.
Old Aug 10, 2010 | 05:05 AM
spray em's Avatar
Might as well. A filter is only a five bucks more. It's worth it in the long run. IMO
Old Aug 12, 2010 | 04:02 PM
Porkchop99's Avatar
Default oil
Thanks for the advice.
I believe the 5 cyl S60 auto takes 6 qts, and I am still googling to confirm this.
Old Aug 13, 2010 | 05:08 PM
MYS6T's Avatar
It takes 5.8 but you really want top use 5.5 The PVC system in a S60 will pull Oil if its over filled and when Oil get Hot it expands so i always use 5.5 quarts.One more thing when you use Syn oil and haven't in the past do get upset if you get an Oil leak or notice the Oil in low.Syn when it gets Hot gets very thin and will find space between the seals while Reg oil runs much thicker and will flow heaver.This is why high mileage Oil is really just 50/50 to help with week seals so you don't get any leaks.Also make sure you check the Oil weight i use 10-w30 in the summer but in the winter i use 5-w20 becasue the oil runs heaver in the cold New England winters.Not sure what year your cars is but used whats recommended
Old Aug 15, 2010 | 07:45 PM
Porkchop99's Avatar
I will keep my eye out for the leaks. I have been going by the reading on the dipstick( anyone actually got an accurate reading on one?).
The other issue that has me concerned is when I changed the filter and had to insert the new one. There is a protruding cylinder or whatever it is that looks like it is supposed to prod through the filter akin to an the way a wheel slides onto an axle. The center hole on the filter was not large enough in diameter to fit so I kinda just forced it on.,,, uh?
Old Aug 16, 2010 | 08:34 AM
Manu Noypi's Avatar
U bought the wrong filter. I would replace it asap if it were my car. U'll never know if something bad would happen anyway they cheap.
Old Aug 17, 2010 | 08:05 PM
Porkchop99's Avatar
Default wrong filter?
I bought the Mahle ox 149 D.
Is this not for the S60?
Old Aug 17, 2010 | 08:16 PM
08s60's Avatar
It's right. I've had to do that as well...some go on easy and some you have to force. I change my oil with Castrol Edge 5W30 and go by the 7.5k oil change light. Last oil change I sent a sample to Blackstone Labs for a UOA. Everything looked great and the TBN was 2.6...Blackstone said I could have gone to 9-10k without a problem. A TBN of 1.0 is low. I know they advertise the Edge as a 15,000 oil, but turbo's eat oil...so with the turbo it won't go that long.
Old Aug 18, 2010 | 10:09 AM
jks2's Avatar
Changing the oil and not changing the filter is like changing a baby's dirty diaper and not wiping his butt before you put a new diaper on. The new diaper is going to be dirty immediately.
Old Aug 18, 2010 | 04:00 PM
Porkchop99's Avatar
That's the way I chg my little one's a few years back ;-)
I called IPD and they confirmed the filt has to be "forced" a bit onto the shaft in order to provide a firm fit. Not terribly intuitive.
Old Aug 19, 2010 | 11:05 AM
jks2's Avatar
Is that your child that had the nickname "Stinky"?
Old Aug 19, 2010 | 07:33 PM
Porkchop99's Avatar
It was bad enuf that I had to chg the diaper, I was expected to W.H.A. too?
ugh!
BenHur
Sep 8, 2015 09:29 PM
tr_car_nut
May 18, 2012 04:07 PM
Arsenal6
Apr 26, 2009 02:34 AM
master_pre
Oct 28, 2007 02:49 PM
nandrolone
Jan 13, 2006 08:28 AM
