1994 850 will not start
Old Aug 10, 2010 | 07:16 PM
rreese96's Avatar
Smile 1994 850 will not start
1994 850, 197000, windows and roof left open during heavy rain, tried to start during storm, would not start. prior to getting wet, started and ran fine, was daily driver, now, will turn over, has good fuel pressure, does not attempt to start, seems to not have any fire ? could the coil have gottn fried, i did have the hood open as i was trying to boost during the storm.
Thanks for the help ;=)
Old Aug 11, 2010 | 06:40 PM
fcpgroton's Avatar
Former Sponsor
Is there a check engine light on? If so, check the codes in the computer.
To be honest, it sounds like a bad sensor. Could be either the Crank Position Sensor or the Cam Position Sensor. The codes in the computer will tell us for sure.
Old Sep 2, 2010 | 05:44 PM
rreese96's Avatar
Default code 324
pulled codes, got code 324, camsfaft position sensor missing or erratic, removed sensor, does not look bad, is there a way to test it ??
AlexMacDonald
Feb 4, 2023 10:31 PM
jcraig0433
Apr 12, 2009 03:18 AM
cmercon
Jan 19, 2009 09:00 PM
animal40
Mar 31, 2008 07:35 PM
debcosta
Nov 27, 2005 08:42 PM
