S40 - P0125, P0128, P0118 - no start
Old Aug 12, 2010 | 12:28 AM
boxpin's Avatar
Default S40 - P0125, P0128, P0118 - no start
A friend called me up saying her car wont start and has been giving her some trouble. She said it has just shut off before. The Rad fan stays on for about 10 minutes after the car has been running. I took my OBD2 scanner and headed over. The car would not start for me, turned over but did not try. I did not have much time but pulled the codes to see whats up.
Here is what I got:
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
P0128 ECT Below Thermostat Regulating Temperature
P0118 Engine Coolant Temperature Circuit High Input
I did not check the fluid level due to time and just not thinking about it. Anyone seen this or might have a clue? Fingers pointing to either low coolant or a faulty temp sensor but I am not sure.
Newport_j
Nov 6, 2014 04:05 PM
docmot
May 12, 2012 11:17 AM
carley
Mar 16, 2012 08:32 AM
edtech1300
Oct 15, 2008 11:54 AM
blackberry
Apr 2, 2008 09:29 AM
