tuner4life's 1998 Saffron C70 Coupe project Thread
Old Aug 12, 2010 | 06:07 PM
tuner4life's Avatar
Default tuner4life's 1998 Saffron C70 Coupe project Thread
Well it looks like it's going to be a fairly substantial project car, so I am going to keep a record (with pics) of what gets done.
We originally purchased this car, a 1998 Volvo C70 HT Coupe, for my wife. She looked at tons of cars and kept coming down to the C70, but she had to have an orange one. Somehow we got lucky and one popped up just a few hours away the same day she sold her old car. It looked to be in pretty good condition, and just needed a PCV system and maybe a wheel bearing. I quickly fixed these issues and in the few months we have had the car, we have also had to fix a c/v axle (snapped under very minor torque), drivers side window motor quit, drivers seat quit (Just need to reattach some little spring that came loose, and the car developed a significant oil leak which I and a few other mechanics believe to be coming from in between the block and head, (mind you, the underside was bone dry when we picked it up.
Anyways, despite all these issues she still loves the car and so do I (and this coming from a saab/toyota fanboy). I will be pulling it off the road in the next month or so and doing the head gasket, all upper gaskets, timing belt, water pump/t-stat, and most likely pulling and resealing the oil pan.
This car was supposed to be a daily driver for my wife, but it i becoming a fairly extensive project, so I will be posting updates in this thread.
But first, pics of the car right after picking it up...
Old Aug 13, 2010 | 11:07 AM
ibified's Avatar
I assume you're providing the cold malted beverages while we work on this, right?
Old Aug 13, 2010 | 04:36 PM
tuner4life's Avatar
absolutely!
Old Oct 24, 2010 | 03:54 PM
tuner4life's Avatar
Alright, I fixed the oil leak. Turns out the hose from the block to the flame trap has a rip in it. I also replaced several vacuum hoses and repaired a bunch of minor boost leaks. Now it runs great! The only problem I an still having is alot of tapping noise from the valvetrain. I tried the ATF trick and it didnt make a difference. So I am assuming I will have to drop the oil pan and change the o-rings. The only problem is that I am not sure how to get it out. it looks like it will just get wedged between the tranny and the pass. side framerail. Also how do I get the steering lines out of the way? Just remove them completely? Could someone who has experience with this job please shed some light on this job before I end up ***** deep in something I cant finish.
Old Nov 10, 2010 | 11:05 AM
tuner4life's Avatar
Ok, I got the oil pan job done. It was a pain, buit I feel confident enough to do it again if I had to.
I also found alot of other problems though....
The air pump is bad and I did some research and found that the cause is most likely a bad valve where the air blows into the exhaust. Anyways that whole system is bad. I was confused though because there were no idiot lights on in the dash. I pluged the obd2 scanner into the car and found a 02 sensor code (bank1 sensor1) and a rich condition code. I am assuming that they are probably caused by the bad air pump. Anyways, I figured that the cel was burnt out so I pulled out the cluster and discovered that the CEL, ABS, TRACS OFF, and SERVICE lights were all MISSING!?!?!?. Yup, somebody removed all the lights. I replaced the bulbs and now guess what, they are all on. From what I have read, the ABS/TRACS light is most likely caused by a bad ABS module.
I called IPD and asked if they could make a tune that ignores the SAS system so I could just block it off. But turns out it is a federal offence to delete a worthless emission system even if I live in an area that doesn't do emissions testing. So I am going to have to fix it correctly. Darn.
So this is the latest chapter in the moneypit that is my wifes car... stay tuned.
Old Nov 10, 2010 | 05:08 PM
elav's Avatar
Jason, I can't believe someone removed all of the lights. The ABS failure is a common one. There are bad solder joints by the large connectors. You can hunt around the internet and find instructions on how to repair this but if you search my name here you can see that I had a great experience removing it, sending it for repair and re-installing it. My cost, including shipping both ways, was $30 and I think that is money well spent as you need to seal it back up so the weather doesn't get in. BTW, I never liked how the C70 handled so I added the IPD anti-swaybars front and back (along with HD Blisteins and new springs) and couldn't be happier. Keep up the great work and add a picture or two!
Old May 1, 2012 | 10:11 AM
tuner4life's Avatar
Back from the dead!!
My wife has been driving this car for the last couple of years. Finally over the winter we were able to park it and I could start making a list of what all I need/want to do to it.
Here's what the plans are:
-pass side cv axle
-pass side trans output seal leaking
-timing belt job/water pump (140k mi and no sign of it ever being done!!!!!! aaaahhh!!!!)
-abs control module (abs and tracs lights are both on.)
-redo entire front end (everything is loose)
-B&G springs
-steering u-joint (steering feels like it's binding)
-15mm rear wheel spacers
-alignment
-replace split vacuum elbows on intake tube
-air flow directional actuator in dash is starting to go bad
-fix several burnt out dash lights
-oil/coolant/trans fluid change
-install 1998 V70R ecu (yes, I win at the junkyard)
-repair drivers window regulator (I rigged it last summer so it kind of works, need to fix right)
-derattle sunroof
-new headlight wiper arms/blades
-new brakes?
-some sort of double din screen (stock radio doesn't work)
-new speakers all around
-and the list goes on, and on, and on... and on.........
Old May 1, 2012 | 10:23 AM
tuner4life's Avatar
This car is pretty much top priority to get stuff done on this year.
The first project I am working on is the front suspension.
-new mounts
-new bearing plates
-new end links
-new steering column u-joint
-B&G springs
-MOOG camber adjustment bolts
-new bilstein struts were put on a couple years ago and still seem to be in good shape, so I am leaving those
Everything went pretty smoothly except for the column u-joint which was a huge PITA. The front of the car is back on the ground though and looks pretty good even after just dropping the jack (springs haven't settled) it looks quite a bit lower. I cant wait to get the back springs in as well.
In progress:
Rebuilt strut assemblies:
One side installed:
Sittin pretty and still needs to settle quite a bit:
While changing the column u-joint I discovered some significant vacuum leaks due to these cracked and split elbows. I will replace them before putting the intake back together. Also need to figure out why the intake tube is covered in oil.
There is going to be a lot happening with this car this summer so stay tuned!
Old May 2, 2012 | 01:11 PM
tuner4life's Avatar
And the rear is done. The rear is surprisingly easy as long as you can get the car high enough to unload the springs after undoing the shocks. Kind of a weird design for the rear suspension, but it's pretty easy to work with. It definitely needs spacers in the rear now. I'm thinking 15mm. According to the manual the rear is only a couple mm narrower than the front, not sure if its the body shape or what, but it seems like a lot more than that.
What size spacers do you guys run on the rear? I'm not trying to hellaflush/poke/etc... just don't want it to look so sunk in.
Anyways, Pics:
Drivers side:
Passenger side:
And stance:
Yes, the garage is a mess.
Old May 2, 2012 | 07:16 PM
MSGTUSMC's Avatar
Nice work!
1998 C70 coupe, HPT, Auto, 38k miles!
Old May 9, 2012 | 08:09 AM
tuner4life's Avatar
Thanks!
Not too much to report at this time. I killed 2 birds with one stone last night. I replaced the pass side trans output seal and replaced the axle as well. The trans was leaking from that seal and the boots on the axle were ripped. So now no more leak and no more grease all over the wheel. yay!
Old May 14, 2012 | 09:10 AM
tuner4life's Avatar
Finally got my vacuum elbows in from fcp. Threw in a new battery and drove it for the first time in months. It desperately needs an alignment. The ABS/Tracs lights went out almost immediately so hopefully I wont have to get a new module for that yet. The cheap hacked together exhaust on the car is now hitting the rear spring, so I'll have to get an aftermarket turbo-back... darn.
Also, the A/C has a leak as it is very low on freon and it was full last summer.... The list never ends, but there is at least progress.
ThePainMayne
Dec 26, 2014 02:07 PM
Peed
Feb 25, 2014 08:37 AM
Rob_C70T5
Nov 13, 2011 09:50 PM
VolvoD
Jun 28, 2010 08:28 AM
mick1232
May 19, 2009 02:59 PM
