Automatic transmission confusion.... Dextron or JWS 3309?33
Old Aug 17, 2010 | 07:40 AM
LarryNH914's Avatar
Default Automatic transmission confusion.... Dextron or JWS 3309?33
Hi,
I am mightily confused by a conflict between the owner's manual and what I read online.
I have a 2001 S40 2.0T. I am pretty sure it has the 5 speed automatic transmission (the floor says: low, 3, 4, drive). Which what I read, and from matching with the mobil site ( http://www.mobiloil.com/USA-English/) I should use jws 3309.
It says her the 4 speed was replaced by the 5 speed in 2001
http://www.cargurus.com/Cars/Overvie...-2001-S40.html
The owners manual says Dextron-Mercron
http://apps.volvocars.us/ownersdocs/...0_09.htm#pg122
This same document describes the transmission as a 4 speed.
What do I use? Do I have a 4 or 5 speed transmission??
I already have the mobil 9903 ATF. Should I use it?
Old Aug 17, 2010 | 08:12 AM
LarryNH914's Avatar
Default I love this part of the owners manual
Power transmission
Automatic transmission: AW 50-50
4speed automatic electronically controlled gearbox comprising a hydraulic torque converter with a lockup function; planetary gear, integrated final drive.
Operation via a floor mounted gear selector lever. Drive shafts with symmetrical joint location. Overdrive.
Final drive ratio 2.76:1
Reduction ratios
1st gear 4.77:1
2nd gear 2.99:1
3rd gear 1.96:1
4th gear 1.32:1
5th gear 1.02:1
Reverse 3.23:1
Old Aug 17, 2010 | 09:42 PM
GerBeGurGya's Avatar
The answer for your question is in threre:
Seems that you got a wrong manual for your car.
jimboy
Mar 14, 2010 04:25 PM
ChrisAce
Mar 1, 2010 11:28 PM
abranz
Apr 8, 2008 04:33 PM
tr_car_nut
Feb 14, 2008 11:34 AM
daver80
Jan 5, 2007 08:00 AM
