S40 engine B5244S7(VIN 39) and B5244S4(VIN 38), are they transferable?
Old Aug 24, 2010 | 04:18 PM
loulou31's Avatar
Default S40 engine B5244S7(VIN 39) and B5244S4(VIN 38), are they transferable?
I have a 2005 S40 2.4i non turbo VIN 39. The engine blew back in January and I am trying to find a used engine to replace it.
What is the difference between engine B5244S7 and B5244S4?
I would like to find out if the engine from a 2004 S40 2.4i non turbo VIN 38 is compatible? What if any modification would be needed?
Thank you!
Old Oct 14, 2010 | 02:14 PM
Daniel Arnold's Avatar
Default Blown engine
The 39 engine code designates a PZEV engine which qualifies for the 15 year/150k mile emissions warranty. Unfortunately that doesn't cover a blown engine or in my case, a failed connecting rod bearing. Please let me know if you came up with any engine replacement options. I have an 05 V50 with the same engine as yours, but replacement even with a used engine approaches the value of the vehicle.
Old Mar 1, 2013 | 11:12 AM
s40 volvo 1's Avatar
Default Go Back Volvo Forums - Volvo Enthusiasts Forum > Volvo Vehicles > Volvo S40 > S4
so has any one found out the differences between the two motors and whats different about them
Old Mar 3, 2013 | 07:33 PM
Hudini's Avatar
I don't know the answer. I did look up the 2 engines in VIDA and noticed that the S4 and S7 were both listed as options for the 2005 model year. Here are some specs. They look identical on the outside.
General data B5244S4 B5244S5 B5244S7
Engine code 38 66 39
Power (kw / rpm) 125/6000 103/6000 123/6000
Max torque (Nm / rpm) 230/1500-4800 220/4000 230/4000
Max rpm 6500/6800 6500/6800 6500/6800
Idling (rpm) 720 720 720
Cylinder bore (mm) 83 83 83
Stroke (mm) 90 90 90
Swept volume (litres) 2,435 2,435 2,435
Firing order 1-2-4-5-3 1-2-4-5-3 1-2-4-5-3
Engine control system Denso Denso Denso
Weight, complete, including oil (kg) 150 150 150
Old Oct 13, 2013 | 07:19 AM
jeffj's Avatar
I know this is an old thread, but have you read this?
Volvo B5244S3 B5244S4 B5244S7 Conversion Engine Swap : EuroPartsHouse Bargain Parts
Old Sep 3, 2018 | 10:52 PM
benzene's Avatar
HI I found a car with vin YV1VW37623F965626 and its engine block casting number reads B4204T .Can you tell me that this engine is belong to which family like t4 or t5 and what is the KW rating of this motor/and type of transmission/turbo.MANY THANKS Edith
Old Sep 6, 2018 | 11:48 AM
pierremcalpine's Avatar
That would be a T4 2000-2004 V/X 40 engine.
Old Mar 20, 2019 | 08:53 AM
Samuel Cruz's Avatar
Default Engine
Thank you!
I have a doubt I'm going to change the engine to a Volvo S40 2.4 The vin number is 39 The one I'm going to ride is 38 What problem can I have if you could help me I'll thank you Thank you
Old Mar 20, 2019 | 09:28 AM
Best to start your own thread - you've commented on a very old thread without stating what your question is. A good place to start is by reading the Volvo Modular Engine WIKI and reading up on SULEV. The wiki has some basic details on the blocks and the version number changes. VIN 38 refers to the B5244S4 and VIN 39 refers to the B5244S7. As noted the S7 is the California SULEV+ variant but the block specs are the same. There's nothing on the Wiki to suggest there's different compression so my guess is the differences are in the engine management, evap and PCV system components, catalytic converter, possibly some heat transfer coatings on things like radiators etc. So what is it that you want to do - ie swap a 39 long block into a 38 car or vice versa or are you talking about buying a 38 engine car to replace a current 39?
blueflames57
Aug 16, 2018 04:58 PM
Joseph Daniels
Dec 25, 2015 08:37 PM
DarkAsylumInc
Jan 17, 2014 01:33 PM
crdeantonio
Dec 6, 2012 01:46 AM
