Broken Plastic Tube near Oil Cap?
Old Aug 27, 2010 | 10:16 AM
bdreyer's Avatar
Default Broken Plastic Tube near Oil Cap?
I have a 2006 XC90 2.5T and noticed that there is a broken black plastic tube about 3/4" in diameter. It comes out of the front top side of the engine just below the oil cap, and continues down the front connecting back in to the engine further below. I think it is just for balancing low pressure?
No engine lights, no change in performance.
What it this, what does it do and where can I replace it?
Thank you in advance.
Old Aug 29, 2010 | 10:55 AM
need2fix's Avatar
its a hose from ur oil trap system it rund between the intake and under the top cover of your engine. it will set the check engine light.
Old Aug 29, 2010 | 01:57 PM
SVTfocusO3's Avatar
You can replace the hose w/o taking major stuff apart, the top cover you have to loosen the turbo hose over it and remove all the t-30s. Hopefully your oil trap is not on its way out, the dealer can do a quick check on it at the dipstick.
Old Aug 29, 2010 | 04:35 PM
bdreyer's Avatar
Thank you for your response. What is this tube called and where can I buy one?
Old Aug 29, 2010 | 04:36 PM
bdreyer's Avatar
What is the tube called? And, where can I buy one?
Old Sep 11, 2010 | 09:33 PM
boyblakester's Avatar
I believe it is called a pcv hose. I realize you have posted this days ago. Have you been able to get this fixed? I currently have the same problem with my xc90 and the dealership is closed until Monday. I'm hoping it isn't to expensive to replace. What is your experiences so far?
Old Sep 12, 2010 | 07:29 AM
It is somewhat expensive to replace. The intake manifold has to come off to replace the hose. Some people might be able to sneak in and replace it without removing the intake.
But you have to remove the throttle body and a few other things to do it.
Old Sep 12, 2010 | 11:08 AM
My regular mechanic said he's can do it. I just not sure he knows what you just told me. Anything you can tell me man would be great I'm planning on taking this thread with me once I get the part. I'm assuming I'll need to get a few gaskets too?
Old Sep 12, 2010 | 05:56 PM
You will need an intake gasket.
Also there might be a bango fitting on the bottom side of the intake manifold by the power steering pump it is a pain to get out.
If you are going that far you might just want to replace the vent box and other hoses as well. This way you do not have to do it again in a few months.
jbrow142
Aug 19, 2015 03:48 PM
bcolins
2001-2013 model year V70
Oct 28, 2013 10:55 AM
mark2765
Oct 10, 2012 05:31 AM
stojakovic
Jul 10, 2009 02:43 PM
MattB850in
Mar 29, 2007 03:55 AM
