2005 V70 A/C High pressure side 17mm nut
Old Aug 29, 2010 | 11:43 AM
chipuc's Avatar
Default 2005 V70 A/C High pressure side 17mm nut
This question is a bit convoluted but the problem has become a real issue since it was 107 here in Dallas just last week.
I decided to check the freon level on our 2005 V70 since it was not quite as cold as it had been. I found what I thought was the low side connection port positioned near the radiator. It has a cap on it that says "6Nm" while taking that off I suddenly heard R134 coming out...I was baffled at what happen since I was only taking the connection cap off. Finally figured out not only was that the high pressure connection but that is for some warped reason has a 17mm nut at the base of the connection which can be tightened. I need to be able to tighten this maybe a 1/4 turn so I can refill the system since all my R134 leaked out!
None of my standard sockets fit so I purchased a "deep" 17mm socket...nope... it will not go all the way down either. Are there any suggestions or a special tool that I can use to tighten this? I it is a amazing tight spot surrounded buy a lot of things that I so not want to take off just to turn a nut a 1/4 turn. Plus it looks like it was designed for a socket and if possible I'd like to use that Vs. a wrench.
Thanks in advance for any tips anyone can give.
Old Aug 29, 2010 | 01:44 PM
SVTfocusO3's Avatar
Maybe a crows foot would fit, I know its pretty tight though. I am not sure if you pull the bumper out a little if you could get a wrench in there. Usually condensers go bad on these cars.
hdw2050
2001-2013 model year V70
Sep 5, 2014 04:08 PM
moreland7492
Jul 22, 2011 03:52 PM
pturner
Jun 25, 2010 11:29 AM
STREETFIGHTER50
Mar 12, 2009 07:29 PM
Patdon10
Jul 24, 2007 08:14 PM
