wheel clearance related. is it springs or struts?
Old Aug 31, 2010 | 03:04 PM
drin's Avatar
Default wheel clearance related. is it springs or struts?
I noticed the rear of my v70 (2.4NA 2004 w/63k) seemed to be lower on one side than the other, so I took out my measuring tape and measured the wheel clearance on all of the wheels. Turns out I was right, but not what I expected.
Fronts measured equal clearance distance (some 2.5 inches or so)
My Right rear measured 2.5 inches,
My rear left wheel measured 3.5 inches!
I also measured the clearances 2x on different level surfaces, but the rear left is always about 1 inch wider than the rest (the rear left part of the chassis is 1 inch higher than the rest).
What does this mean? Spring or strut issue on all but the rear left, or is it something wrong with just the rear left? HELP!
Old Aug 31, 2010 | 11:46 PM
gdog's Avatar
Take it to a frame/alignment shop (most shops that do alignments can't do frame work too) and have them ck it out. They would be able to tell for sure what's going on. Something like that is not easy to diagnose by eyeballing it.
TestPoint
Dec 30, 2013 04:35 AM
boxpin
Jan 22, 2010 11:45 AM
RobC
Jan 26, 2009 01:07 PM
TLC_Lover
Aug 19, 2007 09:03 AM
kildagin
Aug 27, 2006 12:00 PM
