CD Interfaciing Cable
Old Sep 3, 2004 | 04:57 PM
Wentworth Man's Avatar
Default CD Interfaciing Cable
Does anyone have the pinout - or better still a cable they will sell me - for the older style 8 pin mini din CD interfacing cable - pins are arranged 3.3.2
Many thanks in advance
Update:
Well I finally figured it out - seems to be straight throught but....you have 8 pins and 6 wires as two of the wires are double cored and the inner wire is very thin. Take care when you are coldering/ crimping that you dont get a stray wire between signal and signal ground otherwise no signal!
Old Jan 12, 2005 | 08:39 PM
bobdavee's Avatar
Default RE: CD Interfaciing Cable
Did you get this solved? Did you find a plug or cable blank to allow for an after market player to go into the volvo cd changer input?
Puglas
Nov 24, 2005 03:06 AM
GaryBrad
Oct 10, 2005 08:23 PM
danielribo
Aug 26, 2005 11:11 AM
lumanikus
Aug 22, 2005 12:37 AM
jcmartin
Aug 1, 2005 06:18 PM
