Wheels: out of alignment or not?
Old Mar 21, 2006 | 01:21 PM
m1964's Avatar
Default Wheels: out of alignment or not?
I just rotated tires (second time) on our "05 XC90 -car has just over 10K miles- and noted uneven wear : both rear tires are worn out slightly more on the inside then on the outside. Called local dealer, and the service adcisor said that such wear "is normal, and there is nothing wrong w/ alignment if the car does not pull to the side when driving"... I do keep tire pressure at 37-39 PSI (when I remember to check it).
Anyone knows if above is "normal" or not?
thanks
PS
After 7500 mile service my wife noted that tires were underinflated - I checked and found 32 PSI, but she only drove the car for about 2 days w/ that pressure.
Old Mar 21, 2006 | 09:01 PM
Default RE: Wheels: out of alignment or not?
I have heard a ton of complaints of the tires wearing like that on the XC90's.
If you want to feel safe you can have it checked. FYI (Rear Alignment won't really make the car pull to one side unless it is REALLY out of wack.
Old Mar 21, 2006 | 09:49 PM
m1964's Avatar
Thanks, Tech -I made appointment -will update after.
Old Mar 26, 2006 | 12:16 AM
m1964's Avatar
Default Update
The dealer did wheel alignement said it was "slightly out"- now I will be looking at the tires again every 500-1000 miles. These 4 tires are quite expensive to replace...
Old Mar 26, 2006 | 12:20 AM
Default RE: Update
Yes they are espically the 18's
Markvolvo
Nov 27, 2013 08:33 PM
CJ Sinc
Aug 2, 2011 02:15 PM
bluemagicbus
Jun 13, 2008 06:54 PM
ludeless
Dec 13, 2005 07:22 PM
