Stereo Installation Trouble (740GL)
Old Aug 12, 2003 | 08:36 PM
cpayette's Avatar
Default Stereo Installation Trouble (740GL)
I just purchased a 1989 740GL, and unfortunately it has no stereo in it. My roomate owns a 1990 740GL, and when we went to get our CD player installed they said the entire car would have to be completely re-wired because it is common ground. Basically they wanted $400 to install a $200 stereo. The guy at best buy told me this is always the case with volvos. Is this true? And if so is there another way around it besides re-wiring the car? I know electricity and it doesnt make sense to me. It sounds like they are trying to rip me off. How can I check to see if this is a problem in my 89 740GL? Neither of these are waggons, and they are both Sedans. Thanks.
Old Aug 26, 2003 | 02:45 PM
volvo13's Avatar
sounds like they are being lazy. I had an 86 740gle and i put in a Kenwood radio in it. The installer told me that the wiring was different and that he had to simply test the system to see what wire went where, cause there is no wiring harness that is made for it. It cost me 45 bucks to install it. Check elsewhere or try to find a wiring diagram of your radio somehow. </P>
hope it helps.</P>
Old Oct 24, 2003 | 03:22 AM
Erock198's Avatar
I installed a cd player in my 89 740gl.</P>
I went to the stereo shop and purchased a standard 240 wiring harness. I attached the harness to the wiring on the back of the radio and then I went out to the car. I took out the original radio and attached the power harness to the oem plug in the dash. Next I located the amp under the steering column and unplugged it and plugged in the harness from my new radio.</P>
Everything works perfectly and I have great sound. The amp now just sits there unused.</P>
</P>
Good Luck,</P>
</P>
Erik</P>
Old Jun 21, 2004 | 07:22 PM
Pimpin87's Avatar
I installed a new CD deck on my 87 GLE @ Best Buy, and i got free installation under a deal. But the guy said it would have costed me about $40 because it needed new wiring. I think you might be getting jacked. Good luck.
Karen
Feb 14, 2022 07:47 PM
arni76
Nov 15, 2014 10:36 AM
TheVolvoMan
Apr 26, 2004 10:07 PM
TheVolvoMan
Apr 18, 2004 08:44 PM
colson
Jun 24, 2003 11:35 AM
