Can't open gas cover
Old Sep 27, 2004 | 05:15 PM
wjl11's Avatar
Default Can't open gas cover
Hello,
2000 S40.
I can't open the gas cover.
Tried the emergency release in the trunk. Can't get that to budge either.
Any ideas?
Thanks.
Old Sep 27, 2004 | 06:59 PM
Default RE: Can't open gas cover
You might have to try to remove the cover in the trunk and try to unscrew the motor or try to work the emergancy release while looking at it.I havent run into this yet but i will check and see if i can help you out more tomorrow when i go to work.
Old Sep 28, 2004 | 09:23 PM
I looked at one today at work after you pull the cover back you can see the whole motor if you just need to remove it for now there is only 1 10mm screw holding the bracket and the motor in.Once you remove the screw you should be able to slide the motor enough to open the door.If you want to remove it all the way to replace it you might have to remove the power antenna.That is only 1 10mm screw too and the nut on the out side of the body panel. Let me know how you make out.
Old Sep 29, 2004 | 02:46 PM
larese's Avatar
Good luck!
mowntnbkr
Aug 27, 2011 10:07 PM
guptash
Nov 25, 2008 09:39 PM
pierre
Oct 20, 2007 07:37 PM
