rear brake pads
Old Apr 23, 2006 | 02:59 PM
mkotyk's Avatar
Default rear brake pads
can anybody tell me how to change the trick to change the rear pads on a 2001 v40? front...easy-breezy...back...arghhhhh!
Old Apr 23, 2006 | 03:06 PM
Default RE: rear brake pads
You need a special tool to turn the calipers back in.
Old Apr 30, 2006 | 12:08 AM
Ihatespeedbumps's Avatar
I believe snap on sells the correct tool to properly turn the rear calipers back in. I'm not sure of the product # unfortunately.
Old Apr 30, 2006 | 12:24 AM
Most Autoparts stores sell them as well.
Old Apr 30, 2006 | 12:55 PM
reg's Avatar
reg
TECH, if the Volvo calipers that you are referring to are the 'screw in piston' type, then in the past on similar calipers I have simply used a flat piece of metal.............. Audi and Mazda used a similar caliper.
R.
ORIGINAL: tech
Old Apr 30, 2006 | 05:49 PM
They are light the GM calipers. You need to push and turn them at the same time to get them back in.
Old Apr 30, 2006 | 10:20 PM
reg's Avatar
reg
Similar to Audi. I simply took a scrap piece of flat stock and cut it to size, taped it and Voila! I was doing a brake job on a Sunday and so no auto parts store was open. I continue to use my "tool".
Reg
ORIGINAL: tech
Old Jun 1, 2008 | 09:39 PM
ekoracing's Avatar
It's called a "C" clamp use this with the old brake pad (so not to dammage thepiston). Works every time. Snap off tools? NOT worth it.
Johnny Volvo
Jul 12, 2011 11:52 PM
rparker
Apr 1, 2011 01:12 AM
MattS77
Dec 19, 2007 10:31 AM
james07
Apr 6, 2007 04:28 PM
thullz
Nov 7, 2006 09:25 AM
