Tools needed to change brakes
Old Apr 24, 2006 | 02:00 AM
m1964's Avatar
Default Tools needed to change brakes
Any one can list tools neded to change brakes on '05 XC90 V8?
I want to know what I need to remove the caliper bolts -torx or allen and what size.
I am going to do both front and rear brakes.
PS
I just ordered Akebono ceramic brake pads -can't stand the dust on 18" Atlantis wheels -those are not easy to clean.
Thx
Old Apr 24, 2006 | 08:44 PM
Default RE: Tools needed to change brakes
You will need a 6 or 7 MM allen wrench socket. (Forget the exact side I know my socket and just grab it)
Also a straight screw driver,Pliers,Something to push the caliper back(Big pair of channel locks)
And some silicon grease.
Old Apr 24, 2006 | 09:10 PM
m1964's Avatar
Thanks a lot.
Old Apr 25, 2006 | 01:07 AM
Chris_in_Texas's Avatar
Well my 2006 is now just two days old and 145 miles and the front Atlantis Chrome wheels are now black... I guess this is going to be a chronic problem? Oh no its the new body style Expedition all over again!!
Old Apr 26, 2006 | 03:03 AM
m1964's Avatar
yes, volvo makes pads that will color your rims.
I will update after I change to ceramic stuff.
Wonder, what a volvo tech (tech -where are u?) would say about using aftermarket ceramic pads, or anyone else who already used them.
Old Apr 26, 2006 | 09:23 PM
EDIT it is a 7MM allen socket.
Me I like the OEM pads.
Old Apr 26, 2006 | 11:24 PM
m1964's Avatar
First, thanks for update.
Yes, I realized it from your previous posts (OEM parts are the best replacement-you cannot go wrong).
If you had to clean the wheels on Volvo cars, would you still recommend OEM pads?
PS
I am using Rybestos ceramic pads on my 850, they do not feel as "good" as OEM -takes more effort/pressure on the pedal, but-NO RIM CLEANING!
PSS
You would not remember if same socket is good for rear calipers on XC90?
Thanks again
Old Apr 27, 2006 | 01:18 AM
I believe it is the same socket.
Yes I would clean my rims rather than using the ceramic pads.
I always buy the softest pads I can find for my cars. (Which are not Volvo's but would use OEM on a Volvo.)
Old Apr 28, 2006 | 11:19 PM
m1964's Avatar
Akebono claims that their EURO pads are very gentle on rotors wear -is it an idication of the soft material?
They do feel "soft" -pedal does not need much pressure at all, and brakes feel no different from OEM. Maybe, the Rybestos pads are made of harder material - I did not even know about Akebono when I put Rybestos on my 850.
PS
Just checked -Akebono pads are available for 850 too, a bit more money then Rybestos.
Old Apr 29, 2006 | 01:43 AM
I would say yes Softer pads.
suprascooby22
Feb 22, 2018 02:34 PM
comrade904
May 24, 2013 11:32 AM
vrhs2011
Jun 24, 2012 01:05 PM
robsvsu
Feb 2, 2009 06:52 PM
robrike
Oct 6, 2006 12:08 AM
