240 Hi-Po curiousity
Old May 5, 2006 | 01:07 AM
whynotthinkwhynot's Avatar
Default 240 Hi-Po curiousity
I searched the internet for clues, but couldn't find an aftermarket cam for a B230, or much of anything else. The motor is a non-turbo, but I figure there has to be something in the way of modifications for an NA 2.3. I think I saw something (it's been a while) in a PAW catalog. Can anyone make suggestions of where to look, or what to get? Or should I just blow it off for now and start searching for a wrecked turbo car with the same trans? Actually, I know so little about Volvos right now that I don't even know if there's a seperate transmission computer, or if there's even electronic shift on this car.
Thanks in advance for the help, sorry for my confusion. I'm just testing the waters
Old May 5, 2006 | 04:05 PM
Default RE: 240 Hi-Po curiousity
Your best bet is to sell this car and buy a turbo, or save up and buy a turbo.
You can mod a N/A, but you wont gain much. If you got to have power buy the turbo.
Here is what IPD has for you.
"240 1976-95 VX performance camshaft WS0272* $189.00 7.4000 BUY "
"This street performance cam is for B21, B23, and B230F engines in 240 and 740 series 1978 to 1993. Including turbo models. For non-turbo cars you will gain about 12HP and take up to 1.2 seconds off your 0-60 times. Street performance profile increases midrange torque and allows the engine to rev more freely to produce more horsepower. Cam is ground on a new billet.
Easy install takes 2-3 hours. You may need to adjust the valve shims so it is a good idea to have a shim kit and tool available. Also a good time to install a new timing belt and seals."
Old May 5, 2006 | 09:10 PM
In the General section I made a post with links to sites check it out.
Old May 6, 2006 | 12:20 AM
Thanks !!!!
I should be slapped for not reading the read-me's.
Old May 6, 2006 | 09:43 AM
Nah not everyone goes into the General section thats why I remind some people it is there.
insectintellect
Jul 5, 2012 01:49 PM
dman777
Aug 7, 2009 03:19 AM
bne
Apr 6, 2008 05:12 PM
maves75
Feb 3, 2008 04:56 AM
1985_240DL
Sep 20, 2006 08:20 PM
