vented discs on a 142?
Old Oct 31, 2004 | 01:21 AM
cardog's Avatar
Default vented discs on a 142?
Hi, I have been trying to put the vented discs and ATE calipers from a 164 onto a 1972 142s. I have ended up with a very low, soft, and spongy pedal. Any ideas?
I have bled the system several times according to the manual using a power bleeder and still no luck.
Old Oct 31, 2004 | 09:21 AM
Default RE: vented discs on a 142?
Check the front calipers and see how many bleaders they have 1 or 4.If they have more that 1 per caliper make sure you bled from all of them.Some times they will act like that if they arent bled from all the bleaders.You can also try to bleed the master cylinder as well the make sure there is no air there either.
Door Ding
1998-2000 model year V70
May 20, 2013 01:40 PM
tgoulart
Sep 27, 2012 08:45 AM
91shelby
Oct 18, 2010 10:56 AM
daver80
Jul 30, 2007 02:09 PM
datastreamcom
May 7, 2007 04:09 PM
