Vibrates alot while idling!?
Old Nov 7, 2004 | 04:05 AM
YOLY's Avatar
Default Vibrates alot while idling!?
Hi everyone,
I recently got very interested in an used 2000 s40 1.9t @ 43k miles, but I realized that whenever the car is stopped/idling, the car would just vibrates alot, especially the steering wheel. We are currently owning a 96 850 but there is obsolutely no shaking at all. Is it suppose to vibrate like that, or is there something wrong? I heard from various forums that it was caused by bad engine mounts and belts. Thank you for all ur help!
oh btw, since the owner was saying the normal halogen light bulbs went out very fast, so i was thinking about bi-xenon lights, do I have to do a conversion first or can i just plug the competible xenon bulbs in? I know this might be like general info, but I am just not sure anyways thanks again!
Old Nov 7, 2004 | 11:36 AM
Default RE: Vibrates alot while idling!?
The vibration is ciming from bad engne mounts.The most common one is the one on the passenger side of the car front of the engine.You may have many mounts that are bad.There are 4 total the trans mount is the next common one to go bad.The there are the 2 mounts on the bottom of the engine front and rear of the car to engine.Try the one on the passenger side first thats the one that goes bad the most.
Good luck
Old Nov 7, 2004 | 04:24 PM
YOLY's Avatar
ok, i guess i will have to bring it to an authorized volvo shop, since it would be alot more expensive from the dealer, right? thank you tech
Old Nov 7, 2004 | 08:18 PM
No problem any time.
Old Nov 8, 2004 | 08:27 PM
Vender's Avatar
hehe, i KNEW you'd be able to solve it Tech. I directed this guy to you.
Old Nov 10, 2004 | 06:05 PM
Thanks Vender.
Old Nov 15, 2004 | 02:59 PM
larese's Avatar
You have to charge most HID headlights, unless it's just the bulb. Anything under $100 is just a bulb, anything over like $150 is a converstion kit, which needs to be charged.
lukaspanic
Mar 17, 2011 12:32 AM
ryan29121
Mar 3, 2011 03:52 PM
ron1
Oct 22, 2007 07:48 AM
ron1
Oct 18, 2007 05:35 PM
