Transmission Problems
Old Nov 22, 2004 | 01:39 PM
hansolo's Avatar
Default Transmission Problems
Hi
I am driving a 2001 S60 2.0T (FWD) and recently discovered a new problem. In the mornings, when I engage the auto transmission to D, it takes like 2-3 secs before it will engage with a jerk. Someone I know told me that this is a common problem with the s60 and has to do with a sticky/faulty valve body. Anyone can help?
Hansolo
Old Nov 22, 2004 | 02:54 PM
Default RE: Transmission Problems
Yes it is a common problem with the S60's.It could be as easy as a software download.It could also be the valve body.Is the car still under warranty?If so I would take it to the dealer and complain.It could also have something to do with the nuetral control function.In that case they would download software to remove that function.
Old Nov 24, 2004 | 11:58 AM
hansolo's Avatar
Hi Tech
Thanks. The car is not under warranty and I already had the neutral control removed and the software reset. After the reset, it was fine but then the problem came back. If it is the valve body, is that going to lead to bigger problems and if so, how soon shall I fix it.
Thanks.
Old Nov 24, 2004 | 09:55 PM
I would have it fixed soon could lead to more bigger problems.That is about the only part the dealer replaces they dont rebuild transmissions.A new trans is about $2000.00 plus the labor to install it.
GOOD LUCK let me know what happens.
Old Nov 25, 2004 | 02:41 AM
hansolo's Avatar
Ok thanks. How much woudl it normally cost to replace just the valve body in your country?
Old Nov 25, 2004 | 10:02 AM
I will check and post tomorrow.
Old Dec 1, 2004 | 11:26 AM
hansolo's Avatar
Hi Tech
I've recently got a new problem. The last couple of days, the transmission started to slip and the car became sluggish even though the engine revved hard. This disappeared when I stopped the car and restarted. I'm deciding if I should repair or get rid of it. Is this already a sign of more than the valve body fault already? How extensive could the problem be and will it be OK if I fix the valve body?
Old Dec 1, 2004 | 11:36 AM
Replacing the valve body should fix it.I cant say 100% that it will fix it but it should.Do you have any extended warranty?
Old Dec 1, 2004 | 11:40 AM
hansolo's Avatar
No. Can you sort of explain why this is happening apart from the delayed trans engagement? That I understand is because the valve body is sticky and thus the pressure required to engage is insufficient or something like that?
Old Dec 1, 2004 | 11:51 AM
You pretty much have it already.The valve body controls fluid pressure to the gears and if something is weak or not working properly the pressures will be off.These transmissions are very picky about pressures.You can thank GM for that.
Old Dec 1, 2004 | 11:53 AM
hansolo's Avatar
So without the pressure the gear is slipping? This part I can't grasp???
Old Dec 1, 2004 | 12:04 PM
Yes with out pressure it will slip just like if it was low on fluid causing low pressure.
Old Dec 1, 2004 | 12:11 PM
hansolo's Avatar
Thanks.
Old Dec 1, 2004 | 12:14 PM
No problem
Old Dec 1, 2004 | 12:27 PM
hansolo's Avatar
Tech
One more question. WHy is it that when I restart the engine, it becomes normal again?
Old Dec 1, 2004 | 12:28 PM
I believe it is because the computer is trying to do a self test to see if the fault is still there.
Old Dec 1, 2004 | 12:38 PM
hansolo's Avatar
This means that on restart the computer did not detect anymore fault?
Old Dec 1, 2004 | 01:20 PM
Maybe not rite away but all the soleniods get tested while driving.If it then acts up there is still a fault.
Old Dec 2, 2004 | 03:14 AM
hansolo's Avatar
I know it doesn't go away for long. I have accepted the fact that there is a fault.[&o]
So when I restarted and it went away, so fluid has then flowed in and the pressure was normal after the restart (at least until it acts up again)?
Old Dec 2, 2004 | 09:37 AM
Yes that is how it works.
