Amplifier Mounting Advice...
Old Aug 15, 2006 | 08:45 PM
ko_kidd's Avatar
Default Amplifier Mounting Advice...
Does anyone have a recommendation [area-wise] for mounting an amplifier?
I have a 740 if anyone has experience with that model.
Old Aug 15, 2006 | 09:35 PM
Default RE: Amplifier Mounting Advice...
I would mount in the trunk either on the back of the seat or up under the Hatshelf.
Unless it is a Wagon.
A wagon I would mount it to the Speaker box. Or under Seat.
Old Aug 15, 2006 | 10:46 PM
I had both my amps mounted on the back of my seats. I had a sedan.
Old Aug 16, 2006 | 02:09 PM
c70_joe's Avatar
depends if you are bothered about space you can either have it laying flat in boot or vertical against bulkhead, or even on the actual sub box aslong as the heatsinks have room to breath (so amp dosnt overheat) heres some ideas
Old Aug 20, 2006 | 08:41 PM
ko_kidd's Avatar
I was thinking of doing inside the trunk, but I can't seem to find a good place for it yet.
I thought the seat backs were built with wood or something but I came to find out the carpet/backing is cardboard-like. Doing the hatshelf is a little difficult because of the amp being wider than the shelf. I can't really mount it vertically in the boot because I can't go through the wall or I need some sort of piece to stand it vertically.
(It's a sedan btw)
EDIT:
I don't know if you meant upside down on the hatshelf or on the floor--but I'm concerned that not only does the floor-mount require drilling, I'm not sure how I would keep the thing down properly without getting to the other side, and I may hit something I don't want to hit.
Old Aug 20, 2006 | 08:55 PM
ORIGINAL: ko_kidd
(It's a sedan btw)
EDIT:
Man I had two JL Audio amps on my back seats in my 95 850 n/a. There were no problems. They were mounted as is no backing or anything. Just screws they never fell off or anything.
Cherry_Pirate
Jun 18, 2010 07:36 AM
85 760Turbo
Feb 16, 2006 10:13 PM
85 760Turbo
Feb 13, 2006 09:52 PM
Swish
Sep 18, 2005 11:19 PM
mattdoc88
Jun 21, 2005 01:02 PM
