RCA connectors -- which part is positive, which is negative?
Old Aug 24, 2006 | 09:31 PM
ko_kidd's Avatar
Default RCA connectors -- which part is positive, which is negative?
On an RCA plug--for coverting a speaker/or seperated connection that has positive and negative on it--which part is negative and which part is positive?
Old Aug 24, 2006 | 09:43 PM
Default RE: RCA connectors -- which part is positive, which is negative?
Are you just trying to Connect RCA wires to the speaker wires?
If so it won't work you need the Converter box to do it.
Old Aug 25, 2006 | 12:23 PM
cbevis's Avatar
I'm calling shanaigans Tech....you can wire up speaker wires to an RCA plug (for the record, the midle "plug" on an RCA jack is negative) I've done it where i had a couple 6x9's plugged into the rear RCA output on a pioneer. There wasn't really much a difference though.
Old Aug 25, 2006 | 08:53 PM
The Sound Quality Is really Poor and It could Blow the speakers from having it hooked up like that.
RCA's work on a Low Level Speaker wires run on a High level output.
VTBricked
Nov 20, 2010 06:36 PM
iron_rhino
Dec 17, 2008 11:57 AM
lowbeer
Apr 18, 2008 02:14 AM
MagicM1364
Dec 22, 2007 12:02 AM
danielribo
Aug 26, 2005 11:11 AM
