Power, or lack of
Old Dec 14, 2004 | 08:26 PM
moburki's Avatar
Default Power, or lack of
Noob here..testing the waters. Wondering how feasable/expensive it would be to upgrade '98 S70 base model to a turbo car? Anybody do it? I looked at a freinds X-country set-up, looks like a stock system wouldn't be too much trouble, is the ecu swappable? What years might be direct bolt ups from the junk (I use this word hastily as I love salvage yards) yard?It seems the price of a chip would go a long way to a salvaged turbo set up...
thanks in advance for any advice
Old Dec 14, 2004 | 08:59 PM
Default RE: Power, or lack of
You would have to change the ECM,The Engine harness due to boost pressure sensors,cat converter,exhaust manifold, induction pipes, intercooler.Mass flow sensor.
I think that should be about it.
Hope this helps make your decision.
Old Dec 14, 2004 | 09:13 PM
tyrus's Avatar
wouldn't it be easier and probably cheaper to add a supercharger to it?
Old Dec 15, 2004 | 04:32 PM
moburki's Avatar
Is the 850 the same as the s70? that would give me more options for salvage turbo parts. Thanks for the input
Old Dec 15, 2004 | 11:58 PM
Since you have a 98 yes they should be almost identicle.There might be a minor diffrence in the engine control module.
Old Dec 23, 2004 | 04:44 PM
BlackT5's Avatar
It's probably easier to sell your car and buy a turbo model.
The N/A ars have a higher static compression ratio and will not handle a lot of boost. In terms of cost effectiveness, it's cheaper to buy a turbo model.
tab44
May 28, 2009 06:27 PM
lore69
Jan 24, 2008 03:27 AM
johnwilton
Mar 16, 2007 06:52 AM
iworkit
Aug 3, 2006 01:21 PM
Microcat36
Oct 9, 2005 09:25 PM
