Stalling and near stalling problem
Old Dec 14, 2004 | 11:16 PM
volvoinct's Avatar
Default Stalling and near stalling problem
Hi everyone,
I own a 2000 S80 T6 with 93K miles on it. I am the original owner. The car has been great. I noticed two problems wich I originally thought were unrelated but now think are related. One was that the car would stall out while I was driving it. It would always happen as my foot was off the gas and the car was either coasting or decelerating. FOr instance, turning onto a side street or in heavy stop and go traffic on the highway. This happened maybe once every two months or so and has been happening for the last year and a half.
I also noticed while driving at night on back roads that my headlights would dim slightly and I could feel the power steering loose just a little bit of power assist at the same time. This also only happened when my foot was off the gas and while I was coasting. I recently concluded that the car was "almost stalling" and certain power consuming devices were being starved of power, namely the headlights and the power steering. Now when I drive at night and I take my foot off the gas, the headlights always dim a little bit before brightening back up.
I'm not really interested in having the dealer spend alot of time investigating what is wrong $$$. I told them about it and they said they couldn't find anything wrong with the car.
I recently tried using a fuel injection system cleaner and I also try to use a higher grade of octane gas when refueling.
Does anyone have any ideas as to what might be causing the problem?
Thanks.
Old Dec 15, 2004 | 12:34 AM
Default RE: Stalling and near stalling problem
I would clean the throttle body really good.When carbon builds up on the throttle body it plays games with the computer system.Dropping the idle when the idle is lower than normal that will cause the alternator either to not charge or charge very little causing the lights to dim.So I would try that first and see what happens from there.
Old Dec 15, 2004 | 07:45 PM
volvoinct's Avatar
Thanks for your reply. I will try that. Couple of questions. How do I identify the throttle body? I googled the term but could not come up with a picture or description of where it is. And what would I clean in with? Can you give me a general idea of the procedure? Thanks.
Old Dec 16, 2004 | 12:08 AM
Ok when you open the hood look down and find the cooling fan.Look on the engine just infront of the fan.Look for a rectangle aliminum box type thing.It should have a yellow or white sticker on it.That is the throttle body.Also you can follow the black pipe that goes from next to the radiator to the engine it goes to the throttle body.It will be kind of a pain to get to it and remove it.You will need to buy a gasket for it before you remove it.
Old Dec 21, 2004 | 05:17 AM
ajo's Avatar
ajo
ok I'm Having the same problem, My s80 volvo 1999 has 90 now and has been running ok I think. But now wen I'am driving or the car is on stop I see the my headlights are dim and also thein side ligth of the car the did you think I may have the same problems?
also when the car is on full stop it looks like if is going to stall and at the same time my interiar ligth and Headlights will dim too.
Any ideas.
thank you for any infromation.
Old Dec 21, 2004 | 09:50 AM
ORIGINAL: ajo
Any ideas.
Yes I believe you may have the same problem.
Old Jan 27, 2005 | 08:03 PM
volvoinct's Avatar
Quick update. I had the dealer clean the throttle body and PVC today. Approx. $280 dollar tab. Side note: They say I may need a Mass Airflow Sensor in the future.
The car runs much better and it did not seem to want to stall out on the way home (thank goodness). I was going to try to clean it myself but it looked a little difficut with the turbo unit etc...
Also, the service manager said the turbo fans looked almost like new. I guess I'll have to address that problem over the next few months. :-)
Thanks for the advice.
Old Jan 28, 2005 | 01:20 AM
Im glad it is running better.If the pcv was clogged it will throw a mass flow sensor code in the computer.I would not worry about it till it starts acting up again.
Old Feb 7, 2006 | 11:32 AM
Sssnake's Avatar
I have a 2000 S80 2.9 with 92K on the odometer and make be experiencing the same problem, only my car does not stall out. I've noticed that at idle it will surge about 200 rpm and the headlights and interior lights will dim slightly. Do you think cleaning the throttle assembly will correct this or could this be due to a loose belt or something?
Old Feb 10, 2006 | 01:08 AM
JCVolvoS80's Avatar
Well the accessory belt runs the alternator which will charge the battery. I'm pretty sure the electronics all run RIGHT off the battery so it probably isnt a belt problem. If it was then youd probably just keep losing power until the battery ran out. I'd check the throttle body.
Old Feb 11, 2006 | 05:10 PM
Start with cleaning the throttle body and see if it helps.
Old Feb 12, 2006 | 01:47 AM
gordon368's Avatar
ya that mass flow air sensor, its quite expensive, luckily they did my mass air flow sensor under 100% good will, when i asked how much they would have charged me they said about 500-600$...
Old May 14, 2007 | 11:32 AM
slothrop's Avatar
I have a similar problem with my s80 2001. I have trouble accelerating smoothly from astop. And I have the similar problem with stalling at slow speeds or near stop then acceration. I don't have any surge problems. I was hoping it would be a software upgrade, but I'm not sure.
Old Mar 1, 2021 | 02:03 PM
Alice76's Avatar
Default engine stall
I am currently dealing with the same issue with my 2008 S60 over 130,000 miles. I am now convinced it is the engine control module because my check engine light did not stay shut off after the throttle body unit was replaced. It still gave me issue intermittently, but now it won't stay started and stalls right away after starting it.
Will confirm after I've had the dealership look at it next week.
Old Mar 1, 2021 | 02:06 PM
Alice76's Avatar
I am currently dealing with the same issue. i have 2008 S60, over 130,000 miles. I am now convinced it is the engine control module because my check engine light did not stay shut off after the throttle body unit was replaced. It still gave me issue intermittently, but now it won't stay started and stalls right away after starting it.
Old Aug 21, 2021 | 07:50 PM
JDMjesus's Avatar
Ive had the same issues with my 2004 S80, turns out it was an exhaust leak causing the issues. Might be worth a look.
Old Jun 8, 2022 | 03:30 PM
alexo1us's Avatar
So what are the codes? for stalling issue
dim lights first everything runs from battery first your alt can completely die and as long as your battery is good it will run long enough to get you a few miles before it starts acting up How old is your battery if older than 2 years to me start thinking of replacement anyway mine get swapped every 2 years for the biggest I can get will fit. I have an XC90 I have learned that they never shut down or turn the key off they just go to sleep. Let's just say they tend to cook batteries faster than average. here is what I would do to test it disconnect the battery from the car put it on charge slow as possible and wait until it's full which should be 13.5 vols on a 12v battery. if you can't get to full charge with the charger then it's cooked if your charger is like mine you can load test it. but a simple test is to take off charge the good battery should hold 13.5 until something draws it out, or a few months of sitting. if it drops faster. Then the battery needs a replacement.
92brick
Aug 7, 2020 10:20 AM
Jim_Penrod
1998-2000 model year V70
Mar 18, 2013 02:39 PM
chihief
Dec 31, 2008 08:02 AM
Old740
Jul 15, 2008 08:15 AM
JamesVaughan
Feb 1, 2006 06:10 PM
