Replacement of bulb
Old Dec 16, 2004 | 12:59 AM
rcoll's Avatar
Default Replacement of bulb
The light on the A/T shift showing the position of the handle burned out. How do you replace ther bulb? Also what is the US designation for the bulb?
Mine is a 1999 S-70 AWD
Thanks in advance
Old Dec 16, 2004 | 01:08 AM
Default RE: Replacement of bulb
You replace the bulb by removing the center console.Lift up the lid in the back section there is a cover in there remove the cover and remove the 2 8mm screws.Slide the e-brake boot assy towards the drivers side seat to remove and lift the back of the center console and remove.There is 2 white plugs you will need to unplug aftetr removing the e-brake boot.Then remove the bulb and replace.
davej
Apr 22, 2011 08:47 AM
2005s60
Jan 19, 2011 01:50 PM
rsylvester07
Aug 12, 2010 12:12 PM
dads 740 turbo
Oct 24, 2008 06:54 PM
bykrmom
Jul 26, 2005 09:40 AM
