Alignment Issue or something else....
Old Oct 10, 2006 | 11:46 PM
NYSpeedRacer's Avatar
Default Alignment Issue or something else....
Is this an alignment issue or is it something else? My 01 V40 was hit a while back and just got around to fixing it. The front left strut was shifted a little so I replaced it and going to replace the right one as well. But here is my problem. When the steering wheel is straight the left wheel is straight but the right wheel is slight turned the left. So basically the left wheel is straight and the right wheel is turned to the right. Is this an alignment problem or something else? I can't seem to find any other damage. Thanks in advance.
Old Oct 10, 2006 | 11:53 PM
Default RE: Alignment Issue or something else....
Have an alignment done and if they can't bring it in to the proper spec's then something is most likely bent.
Old Oct 11, 2006 | 01:14 PM
Is there something I can adjust that can straighten the right wheel before I take it to the dealer?
Old Oct 11, 2006 | 08:47 PM
If the Dealer is close then I would leave it.
If the Dealer is far away then adjust the tierod to make the wheel come in some.
Old Nov 7, 2006 | 12:01 AM
sandders08's Avatar
ORIGINAL: NYSpeedRacer
It is better to have a thorough inspection of the steering and suspension first before aligning your wheels. As it may be highly possible that your problem is also caused by steering wheel issues, therefore power steering work needs to be performed before doing an alignment.
imaitland
Oct 9, 2012 11:54 PM
Chadley
May 20, 2009 04:11 PM
enjoyer
Jan 4, 2009 01:40 PM
xjflexer
Aug 13, 2007 04:55 PM
ryguy150
Jan 24, 2007 10:11 PM
