2000 Volvo S40 - Brake Rotor Replacement
Old Jan 5, 2005 | 10:50 PM
Boman's Avatar
Default 2000 Volvo S40 - Brake Rotor Replacement
Does anybody have experience removing the rotors from a 2000 S40? I removed the brake calipers, but the rotors don't budge (even with a rubber mallet). There's a large hex nut (about 1.5" diameter) in the middle. Does this need to be removed first?
Old Jan 6, 2005 | 12:08 AM
Default RE: 2000 Volvo S40 - Brake Rotor Replacement
The caliper is a pain to get off because to replace the pads you need a special tool to turn the calipers back in.Then there is 2 more screws that hold the caliper bracket to the rear axle assy.Yes those allen head screws have to be removed before the rotors will come off.
Old Jan 6, 2005 | 11:09 AM
Boman's Avatar
Thanks!
Couple of follow-ups. To turn the calipers back in, are you just referring to pushing the piston back out, or is there something else I'm missing?
Also, do you know what that huge hex nut on the front of the wheel assemble is for?
Thanks again.
Old Jan 6, 2005 | 01:32 PM
You need a special tool that turns the rear caliper piston and pushes it in at the same time.The front caliper piston you can just push in.The big hex nut on the front like in the center of the rotor is to hold the front axle into the hub assembly.You do not need to remove it to replace the rotors.
Old Jan 16, 2005 | 08:50 PM
mdome7's Avatar
has anyone replaced the pads and rotors without that 'special tool' that turns the piston and pushes it in at the same time? why does the piston have to be turned in the first place?
Old Jan 17, 2005 | 12:30 AM
Inside the caliper is a ratcheting assy. that the emergancy brake uses for self adjustment.Im not sure if you have a Harbor Freight store near you but some times they have a sale on the tool and it comes with about 4-5 diffrent adapters for diffrent cars.Most of the time if it is on sale it is like $20.00 for the tool.I think the Auto Parts stores sell them to but not sure how much from them.
Old Sep 27, 2005 | 12:50 PM
rj0828's Avatar
Hi,
My S40 has the allen screw (only one) to remove the rotor. I did remove it and the rotor still doesn't budge. Could it be that it is just that stuck ?? I was also thinking that the axle nut (32mm?) was holding it on(even though I have never seen that in any other car I changed brakes on).
Also, a guy that serviced my brakes before said that I had had a frozen caliper, but I was able to turn the wheels freely. Does that mean he was just trying to sell me new calipers?
Any help would be greatly appreciated !! Thanks. Ron.
Old Sep 27, 2005 | 09:17 PM
Yes most likely the rotor is stuck.
Did you try turning the caliper back yet?
If it is frozen then you won't be able to turn it back.
Old Jun 14, 2010 | 12:48 AM
pilbender's Avatar
Default Thanks for the good tips
You all are awesome! I had to replace the rear brake pads and rotors on a 2000 Volvo S40 and I experienced the exact same things you are all talking about.
That special tool, for rotating and pushing in the rear caliper in at the same time, was a wonderful suggestion. I was able to rent one at my local auto parts for free. Made life a lot easier.
I'm convinced my rotors have never been changed on the rear. They were really stuck good. I banged on them and used a screw driver to pry them loose. But, having someone else mention the hex screw was nice because I've never seen that before. I had only one on each side, but it looked like there could have been 2 at one time. I was also a little puzzled at first because I couldn't understand why the rotors wouldn't come off even after removing the hex screw.
There are only 2 bolts that have to be removed for the rear pad replacement and an additional 2 for the rear rotor replacement, besides that little hex screw. I went ahead and purchased a new breaker bar to bust them all loose. Everything was great after that.
Anyway. These little tips got me through yesterday. Thanks to all of you.
Old Jun 14, 2010 | 11:15 AM
GerBeGurGya's Avatar
For the next time someone gets stuck with the rotors.There is two holes with thread in them on the rotor.It is for to turn a bolt in there equally which in return will push the rotor off the hub.The key is to tighten them equally a little knocking still a good idea.
Old Jun 15, 2010 | 08:28 AM
nattyderek's Avatar
FYI. You can buy a nice caliper tool for $20. Well worth it, if you plan on doing your own brake work.
http://www.harborfreight.com/caliper...kes-40732.html
Old Jun 15, 2010 | 09:58 AM
pilbender's Avatar
That movement you have to do is damn near impossible without this tool. Thanks for the suggestion. I may have to consider this for the future. I would even tell people to not to bother trying to do the rear brakes without it, although it might be possible.
Old Jun 23, 2010 | 05:32 PM
true grit's Avatar
Just ordered it as it's on sale thanks
Old May 2, 2020 | 10:34 AM
AJ Salazar's Avatar
Default 30mm socket
I seen a youtube video and I wish people would answer the question asked instead of going another direction lol. But its a 30 mm socket to take that off
Old May 2, 2020 | 02:41 PM
habbyguy's Avatar
It's a 10 year old thread, and the axle nut had nothing to do with the OP's problem / job. And someone answered thusly in the thread as well. Not sure why the follow-up (or mine, for that matter). ;-)
michaeltroy
Aug 5, 2015 02:47 AM
michaeltroy
Feb 16, 2015 08:30 AM
topkat418
Oct 31, 2013 05:53 AM
rolling2
Oct 20, 2010 01:08 AM
mariettasquare
Aug 3, 2009 02:26 PM
