960 to S80 Engine Swap
Old Nov 14, 2006 | 04:36 PM
JCho's Avatar
Default 960 to S80 Engine Swap
Greetings my fellow Volvo-ers,
I am looking for a new (used) car to replace my 960. The car has sustained extensive frame damage after colliding with a deer. The deer survived, but the car isn't worth fixing (it swiped the entire left side of the car). So I thought about getting another 960 and swapping the engines when it dies. The damaged Volvo has 88K+.
But then I came across a S80 that was a bit more expensive, younger, more attractive, safer, etc. though has a lot more mileage. So my question is, would it be possible to swap a 960 engine into a S80 body? I believe it has the same 2.9L I6 engine, only the newer S80 is transversely mounted and front wheel drive, vs. the 960's RWD longitudinal.
So is it possible? Practical? I know I wouldn't be able to use the same transmission if that decides to go, or body panelling/parts.
Also, is the 960's B6204 (correct me if I'm wrong) engine, an interference, or non-interference engine.
Thank you everyone who responds.
-Justin
Old Nov 14, 2006 | 10:25 PM
Default RE: 960 to S80 Engine Swap
Not sure if anyone tried it yet.
I think there is minor differences between them.
Not 100% sure if the mounting points are the same.
The S80 also has VVT and the 960 doesn't.
Sue Diamant
Nov 28, 2014 04:38 PM
dougsbart
Apr 23, 2014 02:05 PM
chevyfan
Aug 20, 2013 05:14 AM
tyre3d
Oct 6, 2012 09:34 AM
TomOleksy
Aug 8, 2009 03:04 PM
