Maddening '01 V40 Rear Wiper Behavior
Old Dec 17, 2006 | 07:32 PM
unclejosh's Avatar
Default Maddening '01 V40 Rear Wiper Behavior
Hello Group,
Recently I replaced the rear window wiper with a V40 OEM blade from the local Volvo repair shop.
I clicked the new wiper into the arm no problem and drove off.
Since then, the wiper lifts off and does not wipe the rear window during a portion of its stroke:
[ol][*]From 0 to 45 degrees OK[*]From 45 to 135 degrees lifts off and does not wipe[*]From 135 degrees to 180 OK[/ol]The above behavior leaves a pie slice or wedge shaped pattern in the middle of the window............
The wiper blade is symmetrical. The wiper arm is not loose. The wiper arm has a plastic U-shape structure to it, it is not the all metal version.
Anyone out there with any insights ?
UJ
Old Dec 18, 2006 | 01:22 AM
Default RE: Maddening '01 V40 Rear Wiper Behavior
Try bending the arm a little to make it hit the window.
Old Dec 8, 2007 | 08:35 AM
Nickshu's Avatar
Yes I have this exact problem too. I'm going to try to bend the arm. It is mostly plastic, but the lower portion is metal, so I'll try to bend it in a Vise a little bit. It is really maddening. A new wiper arm is $38 from Volvo, but I don't want to spend the $$ unless I'm sure it will actually fix the problem. I'm afraid I'll just end up bending the new wiper arm to make it work!!!
Nick
04 V40
07 9-3 SC
Old Dec 8, 2007 | 02:49 PM
Nickshu's Avatar
Ok so I was able to fix it. Bending the bottom metal part of the arm is out of the question b/c it's really heavy steel. What I did was removed the spring and used a file to grind down the plastic part of the arm where the limit stop for the spring-arm travel is. This allows the spring to pull further than before, so that the arm can keep pressure on the window glass at the top position.
Hope this helps.
Nick.
Old Jun 1, 2008 | 09:23 PM
ekoracing's Avatar
It's not the wiper arm. It is the bolt coming out of the glass.It is weak and bends easely, light pressure will bend it back. Good luck!!!
Old Jun 2, 2008 | 10:25 PM
mncx's Avatar
most of the time we replace the arm... I bend and broke an arm before in the bottom... try lube the spring... if still not working get a new arm
Old Jul 4, 2008 | 02:57 PM
condyboy's Avatar
I had this problem it was the wiper blade catching on the wiper arm!!! Took me ages to spot it. It was just catching where the fitting apperture on the blade ends. hope this helps.
Old Jan 13, 2011 | 09:52 AM
colindawson's Avatar
Thumbs up V40 rear wiper
Thanks for all the suggestions. I've had this problem since I've had the car (nearly 6 years) and this is the first time I've had any success. The two stops mentioned are easily filed off and as it's a plastic moulding I also used a sharp, narrow wood chisel to get the last bits off. Fitted a new Bosch blade and it's brilliant! It's never worked so well since I've had the car.
David Marc Gurewitsch
Feb 27, 2015 01:27 PM
brettmhatch
Mar 21, 2011 08:34 PM
joshuab
Feb 3, 2009 08:22 PM
ivrylineslead
Jul 10, 2008 08:13 PM
DontaviousJones
Feb 29, 2008 05:51 PM
