Trouble with V40 Wagon 56k on it
Old Feb 2, 2005 | 12:03 AM
pts66's Avatar
Default Trouble with V40 Wagon 56k on it
Here are the codes that i got:
ECM A1 - Engine temp Sensor
ECM 5A - 3 way catalytic converter effcy
Next one i couldn't find a match for P0302
misfire Cyl 2
When i drive the car under acceleration, it bucks and stumbles and gets worse the harder i accelerate.
Any help would be greatly appreciated.
Paul
Old Feb 2, 2005 | 01:11 AM
Default RE: Trouble with V40 Wagon 56k on it
Most of the time the hesitation you speak of if from either worn spark plugs or bad coils.You can replace the spark plugs first and see what happens.If it still does it you will need the coils.The cat converter code and the missfire code will be from that problem.I think the coolant temp sensor is another problem.If you want you can fix the missfiring problem and clear the codes and see what happens.
Old Feb 2, 2005 | 10:14 AM
pts66's Avatar
Hi,
Thanks, i'll replace plugs and wires this weekend.
Thanks.
Paul
Old Feb 2, 2005 | 10:44 AM
Your welcome let me know how you make out.
olddaddy
Mar 17, 2009 07:33 PM
RedTurbo850
Aug 19, 2007 10:51 AM
JVC
Jul 2, 2007 11:04 PM
shpeedy
Sep 26, 2006 08:08 PM
