climate control
Old Feb 4, 2005 | 04:37 PM
watson6033's Avatar
Default climate control
All green lights are on in climate face, but blower motor does not run-either in auto or mamual. Any ideas?? Thanks
Old Feb 4, 2005 | 04:58 PM
Default RE: climate control
Sounds like blower motor/blower resistor.They blower motor is behind the glove box.You will need to remove the passenger side lower dash panel and the glove box.Check for power at the blower motor.If you have power there then the blower motor is bad.Most of the time when they go bad it overheats the resistor and it is best to replace that at the same time.
Old Feb 7, 2005 | 02:30 PM
watson6033's Avatar
Thanks tech-sounds like tough job for me-any idea how much a dealer would charge? Dave
Old Feb 7, 2005 | 03:03 PM
The dealer is pretty expensive.It really isn't that hard I think you can do it.It should take you about 30-40 min to do it.
Old Feb 23, 2005 | 08:49 PM
watson6033's Avatar
tech-Got ready to remove blower and thought would give the system one more try--it workrd just-real mystery???? Stray electrons?
Old Feb 24, 2005 | 12:08 AM
Will probably quit again soon.
jfikentscher
May 31, 2006 09:58 PM
JimKW
Feb 27, 2006 08:30 PM
tomservo
Oct 2, 2005 12:30 AM
ccsbennett
Sep 28, 2005 08:51 PM
tomservo
Mar 23, 2005 10:28 AM
