Wheel bearing noise?
Old Feb 14, 2005 | 01:15 PM
Viney's Avatar
Default Wheel bearing noise?
Hi all
I have a 97 UK S40 that has a wheel bearing type noise. its been to the doctors and they have checked it over 100% and can not find any sign of bearing fatuige. They have also checked the differential as well, so i am now at a complete loss.
What else could it be? It sounds like wheel bearing oscilation, and is most noticable between 40-70mph.
any ideas would be great
Cheers.
Old Feb 14, 2005 | 03:30 PM
Default RE: Wheel bearing noise?
Do you know if they rotated the tires?Sometimes a bad tire can make the same noise as a wheel bearing.Try to rotate your tires and see what happens.
Old Feb 15, 2005 | 07:30 AM
Viney's Avatar
Hey Tech
Yes that has been done with no result. Looks like i'll have to change the rear 2 bearings for the sake of it, or turn the radio up louder. Thanks anyway
Old Feb 15, 2005 | 10:08 AM
Try to see if it sounds like it is coming from one side more than the other and try replacing that one first and see if it gets better then maybe the other one as well.
Old Mar 14, 2005 | 05:26 PM
S40RICHIE's Avatar
Hi Viney,
Hope it's not too late and you haven't yet changed your wheel bearings! I have a 2001 S40 which recently had a problem, as I thought, with wheel bearing noise. On returning to the garage they assured me that it was road noise and I was still not happy with this, so took it back again and insisted it was not road noise. Eventually, they decided it was the four wheel alignment which cost them two tyres and eliminated the noise. Hope this helps you.
Old Jun 15, 2005 | 06:10 AM
Viney's Avatar
After all that, i gave up trying to locate the noise. Anyway, replaced the tyres last month, a nice set of DunlopSP1's thank you, and the noise has gone. So it was the tyres after all.
Thanks for alll the help.
Old Jun 15, 2005 | 12:10 PM
Im glad it is fixed.
jfikentscher
May 7, 2008 09:49 PM
fardinina
Aug 14, 2007 03:49 PM
swede850T
Nov 4, 2005 09:29 PM
RocknTommy
Apr 11, 2005 02:18 PM
julyccc
Nov 13, 2004 09:04 PM
