Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and talk about it here.
07 c70 lower control arm removal
Old 11-13-2016, 07:59 AM
BMOORE97's Avatar
Default 07 c70 lower control arm removal
I have tried to remove the lower control arm and both connections to the frame came off very easily. I am trying to remove the final connection point to the wheel assembly. The replacement part looks like the threaded connection point just sits underneath and is attached by the threads and the nut. I saw pictures of an s40 with the same mechanism and the person said, just hit the threaded portion with a hammer to remove it from the wheel assembly. Tried, even tried hitting it with a sledge. Nothing. Any suggestions?
Old 11-13-2016, 10:32 AM
Check out Youtube for some of the vids on replacing wheel bearings on the newer c/v70 models.
f8talh8red
05-21-2009 10:30 AM
etype38
10-13-2008 07:50 PM
sy381
07-02-2008 07:33 AM
tech
02-21-2008 07:52 PM
go2sharks
02-25-2007 12:08 AM
Quick Reply: 07 c70 lower control arm removal
