Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and talk about it here.
551918 kyb shocks
Old 12-01-2014, 02:44 AM
oogamiser's Avatar
Default 551918 kyb shocks
got these thinking they would fit my s60 2.5t awd, but they didn't...now I gotta sell em...never used, they were looked at, and cursed at, then put away til now.
Asking 60 for both, plus shipping...I live in Massachusetts, if you're in southern nh, southern maine, southern vermont, I can drop them off myself, but anywhere else, they will have to be shipped...below is a list I found off of the kyb site...Make sure these will fit your vehicle, double check and check again, all sales are final...pm me and I will respond asap
Year Make Model Submodel Engine Drive Train Notes
1999 Volvo S80 All All All When 551918 stock is depleted, use 553385 · (Exc. Nivomat Rear Suspension ) · Recommended OE Replacement
2000 Volvo S80 All All All When 551918 stock is depleted, use 553385 · (Exc. Nivomat Rear Suspension ) · Recommended OE Replacement
2001 Volvo S60 All All FWD (Exc. Elec. Adjustable Susp.) · Recommended OE Replacement · When 551918 stock is depleted, use 553385
2001 Volvo S80 All All All (Exc. Nivomat Rear Suspension ) · Recommended OE Replacement · When 551918 stock is depleted, use 553385
2001 Volvo V70 Base All FWD When 551918 stock is depleted, use 553385 · Recommended OE Replacement · w/o Electrontic Suspension
2002 Volvo S60 All All FWD (Exc. Elec. Adjustable Susp.) · Recommended OE Replacement · When 551918 stock is depleted, use 553385
2002 Volvo S80 All All All (Exc. Nivomat Rear Suspension ) · Recommended OE Replacement · When 551918 stock is depleted, use 553385
2002 Volvo V70 Base All FWD w/o Electrontic Suspension · When 551918 stock is depleted, use 553385 · Recommended OE Replacement
2003 Volvo S60 All All FWD Recommended OE Replacement · When 551918 stock is depleted, use 553385 · (Exc. Elec. Adjustable Susp.)
2003 Volvo S80 All All All (Exc. Nivomat Rear Suspension ) · Recommended OE Replacement · When 551918 stock is depleted, use 553385
2003 Volvo V70 Base All FWD w/o Electrontic Suspension · When 551918 stock is depleted, use 553385 · Recommended OE Replacement
2004 Volvo S60 All All FWD Recommended OE Replacement · When 551918 stock is depleted, use 553385 · (Exc. Elec. Adjustable Susp.)
2004 Volvo S80 All All All (Exc. Nivomat Rear Suspension ) · Recommended OE Replacement · When 551918 stock is depleted, use 553385
2004 Volvo V70 T5 All FWD When 551918 stock is depleted, use 553385 · Recommended OE Replacement · w/o Electrontic Suspension
2005 Volvo S60 All All FWD Recommended OE Replacement · When 551918 stock is depleted, use 553385 · (Exc. Elec. Adjustable Susp.)
2005 Volvo S80 All All All (Exc. Nivomat Rear Suspension ) · Recommended OE Replacement · When 551918 stock is depleted, use 553385
2005 Volvo V70 T5 All FWD Recommended OE Replacement · w/o Electrontic Suspension · When 551918 stock is depleted, use 553385
2006 Volvo S60 All All FWD Recommended OE Replacement · When 551918 stock is depleted, use 553385 · (Exc. Elec. Adjustable Susp.)
2006 Volvo S80 All All All Recommended OE Replacement · When 551918 stock is depleted, use 553385 · (Exc. Nivomat Rear Suspension )
2006 Volvo V70 2.4 All FWD Recommended OE Replacement · w/o Electrontic Suspension · When 551918 stock is depleted, use 553385
2007 Volvo S60 All All FWD Recommended OE Replacement · When 551918 stock is depleted, use 553385 · (Exc. Elec. Adjustable Susp.)
2007 Volvo V70 2.4 All FWD Recommended OE Replacement · w/o Electrontic Suspension · When 551918 stock is depleted, use 553385
2008 Volvo S60 All All FWD When 551918 stock is depleted, use 553385 · (Exc. Elec. Adjustable Susp.) · Recommended OE Replacement
2009 Volvo S60 All All FWD Recommended OE Replacement · When 551918 stock is depleted, use 553385 · (Exc. Elec. Adjustable Susp.)
rupenzelleo
07-27-2015 07:36 AM
Dead Head
1998-2000 model year V70
06-27-2014 08:28 PM
dman777
03-14-2009 01:32 PM
v70 2.4t
08-10-2008 05:54 PM
dman777
01-14-2008 08:08 PM
Quick Reply: 551918 kyb shocks
