Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and talk about it here.
broken shock absorbeer lower mounting nut
Old 09-20-2014, 10:19 AM
Martijn71's Avatar
Default broken shock absorbeer lower mounting nut
Hi everybody,
I'm new on the forum and absolutely clumsy with this kind of "material". And not a native speaker...
The problem;
My rear shock absorbers (nivomats) and springs were getting old. The nivomats did'nt pump up themselfs and the springs were broken at the top. So I tried to losen the lower mounting nut of the nivomat but the nut broke off. The bolt is welded on to the suspension arm. What to do?!!!
Drill out the old bolt an use a bolt with the same diameter?!
Hope some of you have a anser ;-)
Kind regards,
Martijn.
P.S. The photo I just uploaded I found on internet but the nut on the bolt on the photo was broken off.
Attached Thumbnails broken shock absorbeer lower mounting nut-rear-nivomat-shock-absorber-lower-mounting-nut.jpg
ProStreetDriver
08-15-2013 02:23 PM
paul1149
09-06-2012 11:20 AM
sporky
06-21-2009 08:11 PM
kevo409
04-23-2008 07:51 PM
Quick Reply: broken shock absorbeer lower mounting nut
