Fault Codes
Old 09-14-2005, 10:52 AM
aeabston's Avatar
Default Fault Codes
Hello, I have a really bad sputter or miss when I'm sitting at a stop light and then when I begin to accelerate it's not getting full power and then it will kick in this continues up to about 50-60 mph. I took it to the dealer and they said to start with the plugs. I had the spark plugs changed there has been no change. They gave me a print out of the codes. I was wondering if anyone knew what they were or if they knew what this could be. ECM-4338, 644A, 3502, 3522, 6440, 3503, 3523, They said they checked COMP and it was ok....
Thank you
Amie
Old 09-14-2005, 04:48 PM
Default RE: Fault Codes
I just had the ECM replaced on my '99 S80, I had similar symptoms that you describe. For 1999-2001 models, this has been a huge problem. Check out web site: www.fazmiclaw.com/Volvo.html. They are a law firm in California trying to get Volvo to replaced these items at Volvo's expense, or reimburse owners who have had this done and paid for it already.
Old 09-14-2005, 08:48 PM
ORIGINAL: aeabston
Thank you
Amie
Does it say anything next to the codes they gave you?
Sounds like maybe a throttle body issue but could also be a bad coil/coils.
Old 09-28-2005, 09:43 AM
The problem described is quite similiar to mine that I just wrote here today to seek advise. But in my case, the service, named the problem as transmission problem as the "transmission valve body" has to be changed.
ct60flyer
09-15-2023 06:41 AM
v1lcins
05-20-2022 10:53 AM
bkdunn
11-17-2007 05:22 AM
oldbug
03-03-2007 12:28 AM
uncle
11-09-2006 08:45 PM
Quick Reply: Fault Codes
